Home > Maintenance & Modifications > provent 200 catch can
Tim seymour
Australia
Hi i have just brought a provent 200 catch can and was wondering if anyone has fitted one to the defender pumer yet as iam having trouble finding some where to mount it cheerts Tim Big Cry Cess the Taswegian
Post #222218 26th Mar 2013 4:09am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Loads of options on where to mount it. How about on the left hand wing so the line in comes in e straight line from the rocker cover.
Do you want to return the oil to the sump? If so tapping into the turbo oil return pipe is an option.
Are you venting to atmosphere or into the the stock PCV by the Turbo? www.td5.org
Post #222225 26th Mar 2013 8:24am
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Hello,
I have one fitted, but to a LH drive sorry.
I would not bother returning to the sump, I fitted a clear pipe about 500mm long and capped the end this alows me to keep an eye on the qty of oil which is breathing.
It doesn't really collect much oil but it is filling with water, not the best stuff to return to your sump.
Steve
Post #222287 26th Mar 2013 1:51pm
Tim seymour
Australia
Steve B wrote:
Hello,
Steve
can you put up some photo would be great as long as it is a puma and a provent 200 chers Tim Smile Cess the Taswegian
Post #222513 27th Mar 2013 7:21am
sdj90
United Kingdom 2004 Defender 90 Td5 HT Caledonian Blue
Dont think you can vent to atmosphere in europe anymore, new regs put end to it,
also if you was to do that and bypass the pcv you will see a small rise in crankcase pressure.
Best way at least on a td5 is to do away with the pcv valve and vent direct from the provent to werethe
pcv valve was mounted to the intake
you can adjust for pressure on the provent, also if you do take return to sump or or turbo oil pipe, put
a one way valve in the line.
Steve
Post #222515 27th Mar 2013 8:21am
