![]() | Home > Technical > How high is a Puma 110XS Station Wagon |
TheWarden Member Since: 25 Feb 2013 Location: Southampton Posts: 179 ![]() ![]() ![]() |
Between 2.0m and 2.182m (according to Land Rover)
With my rack fitted, mine is now 2.26.... 2013 Aintree Green 110 Station Wagon SX |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682 ![]() ![]() ![]() |
Mine's 80 inches high...equal to 2.03 metres.
My garage door is 83 inches (2.1 metres), and it's fine when the roof rack is off ![]() You'll be OK unless you've got a roofrack or raised the ride height some way... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
RFAA Member Since: 27 Feb 2013 Location: North Yorkshire Posts: 7 ![]() ![]() ![]() |
Gulp...so its a slow crawl down the ramp whilst breathing in!
Thanks for all your help guys! |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Mine goes under 2.1m sign but I've never checked the 'actual' height of the hanging sign.
My new garage is going to be 2.7 metres high at the door so will work with the top box on (will also take the tin tent so Mrs H is pleased as well! Can't wait to get the door on and the drive finished so we can use it. DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2067 ![]() ![]() |
My 110SW is about 2.04 metres tall.
When the wife gets in it's a lot lower! ![]() ![]() ![]() ![]() Last edited by DAZ110 on 25th Mar 2013 6:26pm. Edited 1 time in total |
I'd check the car park with a tape measure if I were you
CarlW Member Since: 21 Sep 2010 Location: Lanarkshire Posts: 53 ![]() ![]() ![]() |
Also give some thought to any ramps in the car park, with the 110 having a square back end which is at its highest behind the rear axle, as you go down a ramp, just as the back wheels start to go down the ramp the back of the roof will be slightly higher than when you are on the level. MY11 110 XS Station Wagon in Stornoway
The standard radio aerial is higher than the roof. Have it fully extended and watch for any movement if it touches the roof or any other obstruction.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Mine isn't , it's lower than the roof ![]() Be great if it was though. Dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314 ![]() ![]() ![]() |
..It'll fit under 'most' French Toll booth barriers if that's any use
![]() Superspoons |
