Home > Maintenance & Modifications > Fitting a FCX leather sun visor with light and mirror
ZeDefender
Firstly, I apologise this was done on a LHD but cunning use of a mirror or photoshop should sort that out Smile
1. Remove fuse F30 - this is essential unless you want to blow it:
It's the red one in this photo:
2. Unscrew standard sun visors (and send them back to FCX).
3. Gently prize off the see-through cover of the light - fingers are sufficient:
4) Undo the two nuts so the assembly separates from the back plate. Put it somewhere you won't tread on it:
5. You can now detach the live connector (purple wires) and the earth connector (black) and take the back plate out.
6. Making "the hole"... this is a bit daunting (it's in the headliner and could look horrible) but it's fine. The hole is positioned to be invisible to a passenger and driver no matter what position the visor is in. Also, it is just behind the metal roof bracket inside, so you can get your hand/arm in through the headliner opening and forward to get hold of the visor cable end to pull it through:
First, poke (don't drill!) a hole through the headliner with a 3mm drill bit - you'll feel when you get through the tougher part into the cavity. Then use a 4/5 mm bit to make the hole bigger inside. The outside fabric should stretch around the bigger drill bit to keep a tight fit around the cable.
7. Pass the cable into the headliner and grab it from the inside. If you have apelike arms, find a consenting minor to help you.
Screw the sun visor on.
8. Connect the cable ends to the earth on the metal plate and purple/brown (not purple/white) cable on the connector for the light assembly (use the purple/brown cable as it's permanent live). I poked out the OEM connectors and soldered them.
Note the (ridiculous) bare live rails on the back of the light assembly:
This is why you remove the fuse!
9. Put everything back together. You will probably need to fashion some kind of hook to pull the metal plate down when fixing the light assembly onto it.
Note the earthing washer on the RHS - without a good connection to this nothing works properly.
These visors really are great - not only are they functional but they look absolutely "right", except perhaps, that the leather and stiching are better quality than OEM:
As a credit to these visors, my wife didn't notice until she reached up for the crappy mirror she poked up there. When she did, she didn't question me but just raised her eyebrows and grinned Smile))
Matt
p.s. I also apologise if this is incomplete but I been at the wine and I'm off to watch the footy with my son :thumbsup:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #221246 22nd Mar 2013 8:07pm
Killer90
Site Sponsor
Thumbs Up nice write up mate they look great CSK Automotive
www.cskautomotive.co.uk
Post #221250 22nd Mar 2013 8:25pm
Thank you for the write up Matt it's brilliant Bow down
I'm glad you (and more importantly) Mrs Matt like them Mr. Green
Post #221309 23rd Mar 2013 7:58am
ericvv
Tks Matt, good how to...
One question, when unscrewing the sunvisors, do the captive nuts behind the headlining remain in place, i.e. are fixed so that when screwing in the leather ones, those nuts will not have moved out of place/disappeared?
Now that finally there is this how to..., my interest in these wakes up again...
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #221545 24th Mar 2013 5:12am
ZeDefender
Hi Eric
On mine, they are just big fat screws into the metal bracket (the one you should miss when making the hole). I don't think nuts are involved at all.
In any event, everything stays in place - it's a simple screw off-screw on job Thumbs Up
Matt Tell someone you love them today because life is short.
Post #221548 24th Mar 2013 6:51am
ericvv
Post #221549 24th Mar 2013 6:58am
ZeDefender
Please all note - I just looked at my own photo carefully Whistle and edited the "how-to" above as saying use the purple/brown live cable (it looked solid purple at the time) and not the purple/white (obviously stripey) one.
Just to confirm, I've checked it on the Puma wiring diagram - purple/brown comes direct from the fuse box and not via the ECU. In any event, the photo is correct...
In my defense, LR's "brown" stripe is subtle and very purpley, especially in the dim light of the Defender - I'm beginning to think I need glasses Rolling Eyes Tell someone you love them today because life is short.
Post #221552 24th Mar 2013 7:24am
