Home > Puma (Tdci) > Puma 2.2 110 USW gear box noise
stewalex1984
2012 Defender 110 Puma 2.2 USW Santorini Black
Hi All,
Just taken delivery of my 2012 110XS Utility. 1 Previous owner, just serviced by a Landrover dealer with 10200 miles on the clock.
During a 100mile round trip, various city and motorway driving, once the vehichle was heated up I was getting a strange noise / symptoms from the gear box or clutch.
I can only describe it as follows ;
When coming to a stop and dropping it into neutral, it was as if it was partially stuck in gear, causing almost a very light jolt as the engine partially engaged with the gear. After moving the gear leaver around and dropping the clutch etc it would disssapear. Happened more than once on my journey. Should say it wasn't enough to move the vehice easily, but very noticeable.
Any ideas what this could be before I go to battle with the local dealer.
Thanks in advance for any advice.
Other than this issue I'm delighted with it. Sad to loose my Disco 3 that was written of courtesy of another Landrover dealer, but thats another Story!
Great forum as well, very informative
PS, is the terra firma RTC steering damper recommended?
Post #219012 14th Mar 2013 4:32pm
Happyoldgit
Very common and usually caused by the transmission brake needing adjustment. Steve.
http://forums.lr4x4.com
Post #219052 14th Mar 2013 7:27pm
ZeDefender
Definitely agree with MOG (who has suffered my whining about brakes and gearboxes in the past) - the transmission brake is notorious for causing a whole load of "gearbox-banging" symptoms and the clattering of the brake shoes against the drum travels all the way up the driveline. The LR dealer can usually reduce the problem but it's always there (unless you fit an X-brake).
When you have the problem, try pulling the brake lever and releasing it. You may feel the jolt again or find it has gone (for a while) afterwards. Tell someone you love them today because life is short.
Post #219091 14th Mar 2013 8:51pm
Happyoldgit
^^^Ze means gently ease on and partially apply the transmission brake, if you value your transmission you most certainly don't want to go yanking it hard on when in motion Wink Steve.
Post #219117 14th Mar 2013 9:51pm
ZeDefender
Yeah - wot he says Laughing Tell someone you love them today because life is short.
Post #219119 14th Mar 2013 9:54pm
stewalex1984
Got the car booked in with Park of Ayr on Thursday.
Had to agree to possible charge of 3 hours diagnostic work. They are going to remove the gearbox and inspect. Also going to check the handbrake issue.
Also overdue the recall on the turbo pipe too!
Let you know how I get on with them, I noticed Keith on here said he recieved good service from this branch recently, so here is hoping I get them on a good day also.
I have asked for the latest engine management update as well, I believe that can make abig difference.
Thanks for your advice guys, much appreciated.
Post #220233 18th Mar 2013 6:06pm
