Home > Td5 > Cruise control with an overdrive.
Landyphil
United Kingdom 2003 Defender 110 Td5 USW Stornoway Grey
Quick question as search engines are coming up with nothing useful so far.
Has anyone seen a Cruise control kit for a non MSB (ie post 2002) td5 that will work with an overdrive fitted?
Curiosity and all that! Very Happy 90XS Tdci John Eales
110 CSW G4 Edition
88" Series 3 Racer
Post #217039 7th Mar 2013 10:19pm
Killer90
Site Sponsor
Thumbs Up i looked into it for my td5 with overdrive and most say it wont work Big Cry CSK Automotive
www.cskautomotive.co.uk
Post #217041 7th Mar 2013 10:22pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
The Mobile Centre one works, I have a 1999 TD5 with a Rocky Mountain Overdrive. Thumbs Up
Post #217045 7th Mar 2013 10:33pm
Landyphil
I'm no expert on td5 ECU's but isn't that a different ECU being an early td5? 90XS Tdci John Eales
110 CSW G4 Edition
88" Series 3 Racer
Post #217049 7th Mar 2013 10:40pm
yobbie
May be but as I have a Irb remap I'm sure the later programable chip is in there! Ask Tim at Mobile but I'm sure the cruise control will work fine on yours.
Post #217051 7th Mar 2013 10:45pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
The NNN ECU has cruise control built in but won't work with overdrive or higher gearing.
Th mobile centre kit is external to the ECU so may work.
An MSB ECU with a programable chip is not the same and does not have cruise control.
Post #217063 7th Mar 2013 11:19pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
was just going to say the same Whistle Putting Dreams on Drives at JLR Solihull..
Post #217096 8th Mar 2013 10:17am
Porny
Site Sponsor
The mobile centre kit (also available from me Thumbs Up ) works with MSB ECU's... in fact will work with most things. It doesn't car about final drive ratio, wheel size etc etc. Set up is done on the car when fitted.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #217100 8th Mar 2013 10:58am
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Ian
Hi Ian,
Are these in stock now? I have been looking at the mobilecentre website and it has been out of stock for age?
Thanks,
Steve
Post #217103 8th Mar 2013 11:38am
Landyphil
Cheers gents! Guess the Mobile centre is the way to go! 90XS Tdci John Eales
110 CSW G4 Edition
88" Series 3 Racer
Post #217104 8th Mar 2013 11:40am
Landyphil
110 CSW G4 Edition
88" Series 3 Racer
Post #217105 8th Mar 2013 11:41am
Porny
Site Sponsor
Steve B wrote:
Hi Ian,
Thanks,
Steve
I will chase Tim and ask...
Ian IRB
Post #217110 8th Mar 2013 12:02pm
df1
If you have the NNN ecu, it has the cc built in and all that is required is a pulse divider on the speed wire going into the ecu.
I've done it with disco transfer gears. The clock will still read correctly.
I found the speed healer for motor bikes set at 15% reduction in pulse rate has sorted the problem.
Post #217278 8th Mar 2013 9:48pm
Could you elaborate a bit more on this... sounds interesting. Thumbs Up
Post #217280 8th Mar 2013 9:51pm
df1
The wiring up of the cc on the NNN ECU is covered here very well by someone, can't remember where but it goes into good detail.
For the pulse reduction I used Speedohealer by healtech electronics, they make them for bikes mainly and are electronically adjustable, so basically you can increase or decrease the pulse output as a percentage of the input pulse. Just fit this to the speed input into the ECU, a little bit of wiring is all that's needed. Google it, I'm on the iPad and you need flash to view website so I can't post link.
Incidentally I bought it from the French stockist as it worked out cheaper than UK. €100 odd if I remember correctly.
I can take a few photos over the weekend if you want.
Mine works perfectly with the disco transfer gears now.
Post #217287 8th Mar 2013 10:07pm
