Home > My Defender > New 110
Page 3 of 3 <123
ZeDefender
Looks like a great (also as in "large") job.
Seriously though, will you really end up with a "quiet" vehicle at the end of it? Our family (me, wife and 4 teenage children) have driven about 10,000 km in our 110 on holidays and no-one (!) has ever made a serious complaint about the noise...
However, if it would give me the peace and quiet I associate with Mercedes taxis, I would be seriously interested Confused Tell someone you love them today because life is short.
Post #238558 25th May 2013 5:31pm
dgardel
Italy
bpman wrote:
a13x wrote:
bpman wrote:
Superb looking truck Alex.
how much weight in total does the dynamat add ? i like the idea, but adding it to the roof ... i'm thinking it would alter the CoG
I'm not sure exactly but a rough 10-15kg for the roof. Tiny amount in comparison to a roof rack and gear on top. Personally the weight doesn't worry me, no fun going round bends in it quick anyway
thanks Alex ... like the switches too ... air lockers ?
Carling switches Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #238599 25th May 2013 9:47pm
a13x
Couple more bits done;
Some bits from Matt fitted,
Front end in and JW Speaker lights test fit
Cleaned up
Installed
While A bar was off, brackets replaced with metal Mantec part
Plenty more bits still to fit and others planned. Still not fitted the rear trim as undecided whether to fit closed cell foam on top of the Dynamat or not.
Post #239512 29th May 2013 6:07pm
K9F
Have you a link from where you bought the brackets from please? Be interested in purchasing a set myself. Thumbs Up
Thank you. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #239524 29th May 2013 7:24pm
a13x
Flatdog Thumbs Up
Post #239530 29th May 2013 7:45pm
Looking good a13x, thank you for the order Thumbs Up
Post #239647 30th May 2013 10:27am
Pickles
So, the JW Speaker Headlight were just a bolt in.....no mods required at all....just take the OE units out & put in the JWs......and they still work with the headlight levelling, same as originals?
From what I've read, these headlight inserts seem to be as good as you can get?
Cheers, Pickles.
Post #239650 30th May 2013 10:38am
ZeDefender
+1 Thumbs Up
As an added bonus, when I fitted mine I found out LR had fitted one of the lamps the wrong way round and the leveling didn't work properly. Now everything works perfectly - I would NEVER go back to standard lights Cool Tell someone you love them today because life is short.
Post #239654 30th May 2013 11:21am
a13x
Up to near Northumberland for a few days
Post #240430 2nd Jun 2013 12:28pm
a13x
A little more done today.
Carried on soundproofing, this time used foam on top of the Dynamat
Then all went back together and TGE panels installed. Quick test drive and much quieter.
Roof lining will come back out once a roof rack is purchased as will feed in a reverse camera and rear lights. Undecided whether to trim the headlining black too.
Will get some finished pics up.
Post #246677 25th Jun 2013 6:28pm
jayaway44
2012 Defender 110 Puma 2.2 USW Stornoway Grey
Hi there can you give us some details on the foam on top of the Dynamat set up, where did you get the foam and is it just a spray adhesive you used.
Thanks 2.2 2012 110 utility Orkney Grey
Also
Range Rover Evoque - Surprising but I like it.
Previous
Freelander 2 SD4 HSE - Black
90 TD5
Discovery 3
Early Discovery.
Post #246881 26th Jun 2013 9:35am
cozz
so i need to take off my rear trim panel to do some sound proofing
are they easy to remove ?
Post #247638 29th Jun 2013 7:35pm
Innuendomaster
Loving the Jw Speaker lights, definately on my list when I'm off to Kentucky. Plenty of sellers are putting me off as they "they are not European versions" if bought in the USA. However speaking to JW Speaker they can supply what I want in Euro spec
Post #247640 29th Jun 2013 7:41pm
Page 3 of 3 <123
