Home > Maintenance & Modifications > New loom for both headlight relay upgrade and add'l lights
Page 2 of 2 <12
leeds
The connectors in the photograph are superseal connectors and not econoseals connectors.
Same company makes them but the superseal connectors are a more expensive item and in my mind give a much better seal against water ingress.
Brendan
Post #300805 21st Jan 2014 10:19am
LR90XS2011
ZeDefender wrote:
Also, if you're looking at R123 on page 62 of the Electrical Wiring Diagrams issue 1c manual, there's only one relay and it looks as though full current from the lights is going through it and the lighting switch?
For a minute there I thought I had wasted my time and money buying the dutch relay loom, however having just studied the drawings I concurr with ZeDefender that full current still appears to go throught the column switch despite there being a relay in the circuit. It appears the relay is just there to control the lighting systems logic DEFENDER 90 TDCI XS,
Post #301037 21st Jan 2014 9:40pm
ZeDefender
In any event, I measured the difference with the new loom - a 0.7 volt increase is good in anyone's money Thumbs Up
*Edit* and if any existing relay was doing its job, the light switch wouldn't burst into flames Whistle Tell someone you love them today because life is short.
Post #301041 21st Jan 2014 9:44pm
landy andy
Is the relay in the standard system to provide, stop power due to ignition position? So when ignition is off it cuts the headlights to sidelights only?
Andy
Post #301045 21st Jan 2014 9:51pm
NoDo$h
Yup Thumbs Up
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #301047 21st Jan 2014 9:55pm
Page 2 of 2 <12
