Home > Technical > anyone had this problem? |
womble Member Since: 27 Jan 2012 Location: south east Posts: 272 |
evening all ,currently in greece and NO it is not hot,sometimes when i turn on my indicators my wipers start to go and i cannot turn them off!!before this happened i fitted a new indicator switch assembly but that was a good few thousand miles ago and this problem has only started a couple of weeks ago.thanks for any ideas in advance.
22nd Feb 2013 9:10pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
what switch did you go for was it a cheap britpart one Best one to go for is the Lucas one which is a allmakes or britpart OEM spec, or buy genuine CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
22nd Feb 2013 9:17pm |
can't remember but could have been the cheap one(the more i hear about that brand the more i distrust them)so,you think it could simply be the ind.switch assembly?
22nd Feb 2013 9:35pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6264 |
bad earth?
can do strange things! but not had that actual problem. - not to self - not had indicator / wiper problem so count myself lucky. |
22nd Feb 2013 9:38pm |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
- note to self - not had indicator / wiper problem so count myself lucky. [/quote]
YET |
22nd Feb 2013 9:43pm |
Britpart gets a lot of stick but purely as most of there branded parts are shocking Get the Lucas one mate its half the price of a genuine one but the same quality Can be brought from a Britpart supplier, MPS trading has my great service and im sure if you contact them they can sort you out a good price CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
22nd Feb 2013 9:53pm |
thanks all.will check out the earth when i get home ,if not yhat then new parts!!stiil,think myself lucky its not a modern car packed full of mostly unnecessary electronics
24th Feb 2013 10:55am |
update on indicator problen. tured the lights on the other night and the radio cut out,the wipers came on(could'nt turn them off!!) and the main beam light was lit very dimly.now i think it is an earth issue.have any of you experienced this and know a quick fix
24th Mar 2013 2:27pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4485 |
A long shot, but if it is a Puma the Earth strap is screwed on a chassis outrigger beneath the drivers feet. You can see it if you look behind the front wheel. Check that it is still fixed FIRMLY to the outrigger. Also check that the battery terminals are securely in place. 1982 88" 2.25 diesel
24th Mar 2013 4:32pm |
not a puma but will check these things any way.cheers spudfan
24th Mar 2013 8:09pm |
interesting.another thing to check.
re the radio it completely shuts down,no illumination,dead!! the only way ican stop the wipers shuddering across the screen is to pull over and switch off the engine and then go again. oh,and just to make it more of a pain it's an intermittent fault. |
24th Mar 2013 9:19pm |
anyone heard how wurzel is getting on ?
24th Mar 2013 9:20pm |
yeah,i,m clearing customs in uk,lr on the to do pile,how are you getting on caterham?
26th Mar 2013 11:23am |
thanks for asking.
I also have a to do list (they're jobs I can do and therefore no one but me to blame if they ain't done right). I'm pretty much all sorted me thinks. I'm looking at getting a new MAP sensor as I've given the current a jolly good clean and mr truck appears to be working faultlessly now (most of the time). I have to say I am wondering if there's an element of me having intermittent hearing. before injector learn (thanks again porny for that) there was serious injector noise but following that and the MAP sensor clean most of the time mr truck runs sweet ie circa 40 mph top gear incline and couldn't hear anything - was so staggered I had to turn the stereo off and open the window......all I could hear was the buzz / induction noise I've cleaned the map sensor a couple of times and I'm very much of the opinion that this is the weak link but having been told they're £100+ plus to buy I'm trying to see how / if I can get a replacement through warranty.? wishing you hadn't asked when you get time would like to know how you get on sorting you probelm(s). good luck. |
26th Mar 2013 1:29pm |
