Home > Technical > Sikaflex 291 as a gasket sealant
excossack
Is Sikaflex 291 any good as a gasket sealant coupled with a proper gasket?
The reason for asking is I have replaced my rocker gasket on the TD5 at least twice maybe three times with Gen LR one and after-market ones. I have tried just gasket and tried with Hermitite red and blue. The leaks return after a few months, Namely the half moon at the rear of the rocker and above the intake manifold.
The other Censored is the front plastic disc on the front of the engine. Again, Gen LR and after market ones. With and without gasket sealant.
The only difference on my 99' Td5 is I have an AMC head.
So having used red and blue sealant I am thinking of trying Sikaflex 291 as I have some,
if its no good, what sealant is good?
Oh and also tried the sealant used by LR to seal the sumps on Pumas.
I have checked the rocker breather and that's clear and done the bolts up to specified torque.
Or is a LR thing and they all leak? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #213039 21st Feb 2013 9:15pm
GUM97
I'll give a Thumbs Up to Sikaflex for most leaks! It's worked a treat to seal my sump, and a few other things Very Happy An engine to TDi for!
Post #213040 21st Feb 2013 9:18pm
excossack
Cheers. Its getting annoying! 1999 Defender TD5 110
Regards
John M0VAZ
Post #213043 21st Feb 2013 9:20pm
K9F
Whilst Sikaflex 291i is brilliant stuff it can only be used in temperatures of -40 to +90 on the rocker cover I would use Holdtite RTV853. Better than Sikaflex in a hot oily environment and used prolifically in the marine engineering world.
http://www.multibondsolutions.co.uk/index....gory_id=10 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #213281 22nd Feb 2013 5:37pm
excossack
Cheers K9F. If its good for Marine environment and upto 270 deg'c then it could be worth a dabble.
Maybe that's were I am going wrong and the Hermattie blue/red is breaking down with the heat? 1999 Defender TD5 110
Regards
John M0VAZ
Post #213301 22nd Feb 2013 6:21pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Have you checked if the head is warped or twisted. If it keeps blowing gaskets it sounds like something isn't right..?
Simon
Post #213305 22nd Feb 2013 6:29pm
excossack
I hope its not warped or twisted as it had a new head about 3 years ago. 1999 Defender TD5 110
Regards
John M0VAZ
Post #213306 22nd Feb 2013 6:31pm
couplands
Might be worth putting it on a flatbed to check next time you take it off..
Post #213308 22nd Feb 2013 6:33pm
K9F
I wouldn't fret about a warped head just yet. Degrease as much of the rocker cover gasket surface as possible/practical. Try the Holdtite as it is 'fit for purpose' and a high grade and effective sealant and I reckon you'll have no further worries.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #213310 22nd Feb 2013 6:35pm
excossack
Its not the head I am taking off! But worth checking the flatness of the rocker. 1999 Defender TD5 110
Regards
John M0VAZ
Post #213311 22nd Feb 2013 6:35pm
BigMike
Use permatex aviation number 3 or loctite 515
Post #213442 22nd Feb 2013 10:23pm
df1
I'd imagine most of the products mentioned will do the job just fine.
I use Wurth products for various jobs and find them very good quality.
Post #213496 23rd Feb 2013 8:40am
