Home > Maintenance & Modifications > Rear Crossmember
x-isle
Rear Crossmember
Took advantage of the weather this morning and treated the rear crossmember to a fresh lick of Satin Black.
Set up a timelapse too, will post that up once I've edited it.
 Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #207595 2nd Feb 2013 2:48pm
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
That looks fantastic and makes me want to do mine.
Post #207598 2nd Feb 2013 3:02pm
Rakthi
2011 Defender 110 Puma 2.4 HCPU Stornoway Grey
Stupid question, what kind of paint, and did you brush it on or sprayed it? (just asking as might have to do this in a year or so)
Looks really nice and smooth. Thumbs Up
Post #207603 2nd Feb 2013 3:09pm
ericvv
Don't wait a year! Better to do it from new before any sign of rust would appear. Satin paint at the outside and thorough Dinitrol or other anti rust treatment at the inside should keep your crossmember as new Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #207606 2nd Feb 2013 3:14pm
x-isle
Wire wool to get the small amount of surface rust off. Then some primer (normal not etching) then Satin Black.
Timelapse video will show it all......coming soon. Craig Rogers
2007 Puma 110 XS
Post #207609 2nd Feb 2013 3:25pm
Rakthi
OK, added to the "things to do" list. (a list that seems to get longer every day)
Post #207613 2nd Feb 2013 3:29pm
K9F
I've always sprayed mine from day 1 after cleaning with a good liberal coating of WD40 and periodically in between. Looks as good now as when I got it!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #207614 2nd Feb 2013 3:31pm
ericvv
Post #207615 2nd Feb 2013 3:32pm
Thud
And stainless bolts are a must too to set off the whole fancy look.
Post #207617 2nd Feb 2013 3:33pm
ericvv
Post #207618 2nd Feb 2013 3:35pm
Lorryman100
Mine was done last September and still looks like new,
All of my ones on the crossmember are stainless except for the towing bracket fixings as they need to be a high tensile. :thumbsup:
Post #207682 2nd Feb 2013 7:09pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Good paint for chassis / rear etc.
http://www.frost.co.uk/marine-boat-restora...473ml.html Original Member Pie n Pea Club.
110 HCPU Tipper
Post #207685 2nd Feb 2013 7:13pm
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
Lorryman,
You might look after your Cross Member but you don't weed your driveway Rolling with laughter
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #207687 2nd Feb 2013 7:15pm
Lorryman100
They get buried once a year anyway when I add a couple of tons of red chips, easier than raking them back from my neighbours driveway. Whistle Very Happy
Post #207692 2nd Feb 2013 7:21pm
x-isle
Timelapse from earlier!
http://defender2.net/forum/post207787.html#207787 Craig Rogers
2007 Puma 110 XS
Post #207788 2nd Feb 2013 9:32pm
