Home > Puma (Tdci) > JW Speaker 8700 LED Lamps MOT Failure
jav-uk
England 2014 Defender 110 Puma 2.2 SW Alpine White
Hi All,
After three very happy years with my 110 it had its first MOT today at the main dealer and it failed on several items.
Most concerning was the headlamps, my units are just over two years old and both have failed.
Tried calling mobile centre to discuss the problem but all I get is the answer phone.
The dealer wants me to refit the original units to get it passed.
Anyone with LED headlamps had a similar issue?
Paul Paul
Pondering a New 90 Commercial
2020 Evoque
* 2014 110 SW JE Stage 2.
*2010 110 Utility. JE Stage 2.
*2007 110 SW
*2003 90 JE Stage 2.
*2000 90 SW
If its not leaking it ain't full.
Post #207354 1st Feb 2013 5:01pm
dgardel
Italy
Re: JW Speaker 8700 LED Lamps MOT Failure
jav-uk wrote:
Hi All,
Paul
why the 8700 failed? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #207359 1st Feb 2013 5:16pm
My old (59 plate) past so you need to find out why are they to high etc etc
They are fully compliant so who tested it ?
Post #207364 1st Feb 2013 5:31pm
jav-uk
I have just received the paper work;
001 NSF Headlamp aim to high [1.8].... okay, I can adjust this.... although I never get flashed by oncoming vehicles.
002 OSF Headlamp aim beam image obviously incorrect. [1.8.A.2]
I have a drawing showing the pattern, apparently my headlamps show
and it should look like this
|____
There is some condensation in the OSF lamp glass but I never thought it would ruin the beam. Paul
2020 Evoque
*2007 110 SW
*2000 90 SW
Post #207365 1st Feb 2013 5:31pm
Lorryman100
Me too, and a unopened pm on here from before Christmas. Confused
Exactly my problem, but in both lights. So much so its starting to run down the inside of the lens. Big Cry
Post #207374 1st Feb 2013 6:04pm
ibexman
Ive had mine 3 years no problems seems a bit of a jobsworth how long does it take to adjust a lamp , i always find independent MOT Stations more helpfull Thumbs Up
Post #207376 1st Feb 2013 6:07pm
K9F
jav-uk wrote:
........ it had its first MOT today at the main dealer and it failed on several items.
What else apart from the lights did it fail on? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #207379 1st Feb 2013 6:11pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
I've had mine mot'd no problem at all, in fact the mot guy commented on how good the beam pattern was.
Post #207407 1st Feb 2013 7:18pm
Can't comment on the problem you're having but I do know that Tim from Mobile Centre has been very poorly since before Christmas and is only now starting to deal with enquiries from his sick bed, I'm sure he'll be back to you very shortly
Post #207411 1st Feb 2013 7:28pm
mk1collector
Who fitted the headlights and did they fit them correctly and align them?
Post #207416 1st Feb 2013 7:31pm
K9F
When I fitted mine myself I just took the old ones out and fitted the JWS without moving the adjusters and they were spot on MOT time.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #207428 1st Feb 2013 7:48pm
jav-uk
Thanks for all replies, sorry that Tim is not so well. Hope he's back fit asap.
MOT failed usual stuff, rear shocker bushes and wiper blades. Bushes can be done before warranty expires in two weeks.
I fitted the lamps myself, it's a straight forward replacement job and then took them over to a mate that run's his own MOT business and he tested them, he advised they were some of the best lamps he had seen. Very clean cut off and ultra bright.
So for them fail an MOT just two years later was a bit alarming. Shocked
I will replace them with the old units to get a pass and will try Tim to see about warranty replacement.
As my 110 is nearly out of warranty I decided it was best to let the stealer do the MOT, and pick up any warranty jobs.
Typical they fail lights that are aftermarket and the best upgrade you can put on your vehicle in my opinion.
Post #207437 1st Feb 2013 8:07pm
leeds
The Speaker 8700 are fully road legal in the UK.
It appears that the MOT failed the headlights on their aim rather then on them being not OEM.
Our 110 has passed its MOT with the 8700 fitted no problem.
Condensation in LED lights can occur. They are typically fitted with a Goretex type filter. This allows the light unit to breathe. Given the correct weather conditions the lights should dry themselves out.
Brendan
Post #207461 1st Feb 2013 9:01pm
davew
You don't say why the lights were failed... or did I miss that bit ???
I'm assuming it wasn't alignment as changing them won't fix that. http://www.yorkshireoffroadclub.net/
Post #207504 1st Feb 2013 11:14pm
K9F
Yes you missed it! One was alignment the other beam pattern....
In a nutshell.....
OSF Headlamp aim beam image obviously incorrect..
Post #207505 1st Feb 2013 11:23pm
