Home > Technical > Power coated rear light guard to match genuine rear Ladder
x-isle
My Landy was factory fitted with the light guard access ladder (STC50417) like this one;
I want to put a light guard on the other side to match, the sort of backwards L shape.
I've seen plenty of them, but they seem to be painted rather than powder coated like the ladder.
Does anyone know if there is indeed a matching guard?
Thanks Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #206951 30th Jan 2013 10:01pm
x-isle
Ahhh, looks like I've sort of found the match, however, it comes as a pair which I don't need.
http://www.rimmerbros.co.uk/Item--i-RTC8860AA
However, it states pre-02 which mine isn't.....? Craig Rogers
2007 Puma 110 XS
Post #207012 31st Jan 2013 12:41am
The pre '02 had a square fog light, so the bottom bit of the guard will be longer.....
I think???
Post #207026 31st Jan 2013 8:18am
All of those "genuine" type guards I've seen have been powder/plastic coated, not painted.
Post #207034 31st Jan 2013 8:41am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I think???
Mines a 2001 and its got the round lights. I think the square ones were on the 300Tdi.
I have the lamp guard, so will take a picture later.
Simon
Post #207038 31st Jan 2013 8:53am
Re: Power coated rear light guard to match genuine rear Ladd
Frankly, given the usual quality of Land Rover powder coating, you'd be better off with a painted one anyway. Darren
Post #207043 31st Jan 2013 9:09am
grafty99
Square rear lights were on Td5s too until the 2002 "facelift" which included round fog lights, one piece pressed steel rear door, new dash etc. 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #207044 31st Jan 2013 9:10am
x-isle
Cheers all, makes sense.
As for being better off painted, maybe, but that doesn't help unless I also take the ladder off and paint it.
Masai's is pretty close to it and as they are only down the road, I've asked if I can go and match it up. Craig Rogers
2007 Puma 110 XS
Post #207049 31st Jan 2013 9:37am
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
i have the L shaped (original LR overpaid but still non rusty) one on mine (the one for the round lights/puma); don't waste your money and time (and drilling holes in your car)
My 235/85 AT tires bumped in it from first day; denting the body ripping out the rivnut slowly and deforming the thing.
Tried to bend the mounts so it would be more outwards but it needs to come outside of the body like 1 inch before it clears the wheel.
That all is if you have a stock wheel carrier which i expect as this lightguard can't be used with an aftermarket wheel carrier (mantec type etc)
Now, on the sunny side, i have mine laying around now i am putting a spare wheel carrier so PM me if you want me to throw it in the post for you (beware i'm in Slovakia and you will be paying postage Cool, only)
Smile
Post #207190 31st Jan 2013 10:09pm
x-isle
Thanks for the advice!
Much appreciated. It was a concern thats now a bigger concern.
Possibly why LR don't have the matching one. Craig Rogers
2007 Puma 110 XS
Post #207197 31st Jan 2013 10:16pm
couplands
No, mine is pre facelift, has 2 piece door etc, but all round lights, no square ones....it's a TD5 2001 (51 reg).
I guess there was a transition period.
Simon
Post #207198 31st Jan 2013 10:24pm
x-isle
Aha! There is a newer part number for 2002 onwards;
STC53157 Craig Rogers
2007 Puma 110 XS
Post #207211 31st Jan 2013 11:07pm
