![]() | Home > Maintenance & Modifications > MTBer question! |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2673 ![]() ![]() ![]() |
Have a look at WarPig's excellent write-up...
http://www.defender2.net/forum/topic11901.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Odin Member Since: 29 Apr 2011 Location: Aberdeenshire Posts: 237 ![]() ![]() ![]() |
Thanks Martin
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2965 ![]() ![]() |
You need GREENI
What? I sensed a mention of my name !!!
Warpigs write up is fab ![]() Another option which you could use ..... You could put these on the rack permanent, though you'd need put the front wheels inside, or on the rack... The good thing about these is, they 'lower' the profile and look 'pro' ![]() http://www.cyclestore.co.uk/productDetails...goryID=786 Note to Martin....Sorry if I'm breaking rules, I do work for these, but I don't own it, so I gain nothing, I'm just trying help Forum members ![]() Odin, let me know if there's anything else I can help with. |
Other options that fit inside are
http://www.cyclestore.co.uk/productDetails...goryID=786 And possible to adapt to bolt on the rack... http://www.cyclestore.co.uk/productDetails...goryID=786 |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
odin - just check that if the bike rack is a front wheel removed type (as shown by greeni) that it is compatiple with disc braked bikes - some early racks weren't!
