Home > Puma (Tdci) > Kenlowe Hotstart
Dean Watson
United Kingdom 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Kenlowe Hotstart
Hi All
Anyone fitted a Kenlowe Hotstart in a TDCI, im thinking of fitting one in my 110dc an i wondered if anyone knew which hose is best to fit it in.I know a Webasto would be better but i havent got that sort of cash and i reckon at least one warm start will do more good than none at all.
Post #204428 22nd Jan 2013 8:13pm
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Hi Dean,
Why do you want one?
Most of the guys here that have Webastos fitted are visiting areas where extreme temperatures are a risk. But my experience is that even at temps as low as -20 you don't necessarily need a pre-heater. Plenty of guys in scandinavia run around without pre-heaters in the winter.
The Kenlowes seem to be priced at around £300 from a quick google search, you can get all the parts for a webasto install secondhand from the bay from a similar amount, my most recent install cost about £350, but this included a webasto timer (£70) which could be replaced by a simple switch if you buy the right heater.
Not only is the Kenlowe limited by the fact it needs power but also can't be used as an auxiliary heater when driving.
As for hose, I would have thought go for the same one that webastos are plumbed into which is the feed to the cabin heater valve. Details in The Webasto Thread.
Post #204439 22nd Jan 2013 8:31pm
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
When I looked into 240v systems the general feedback from cold climates was that the DFRA kit was the best suited.
With the kit you get an air heater and a core plug heater. I was however persuaded by others that pointed out the diesel heater offered greater flexibly especially if you were parked in a car park with no power hook up.
Jason.
Post #204440 22nd Jan 2013 8:33pm
Dean Watson
Re-Kenlowe
Its really just to get the truck up to temp quicker(and save on engine wear) on short trips,as said id love a webasto but im a bit put off by buying a secondhand unit and then having to fit it which doesnt seem exactly straight forward.
Just thought the Kenlowe for £250.00 might do the job and save some engine wear into the bargain?
Post #204441 22nd Jan 2013 8:34pm
jasong4110
Re: Re-Kenlowe
The DEFA ones are about £200 for the air heater and core heater, you can also get a battery charge module with them.
Jason.
Post #204446 22nd Jan 2013 8:41pm
Phoenix90
The seconda hand units are generally fine, and easy to service at home. The installation can be tricky but it's mainly just a case of taking time.
I just think the electronic ones are a bit of a pain. You have to have power laid out everywhere you'd like to use it regularly and I get the feeling after a while i'd stop using it.
You also have to make sure the timer is set every time for at least 20 minutes in advance whereas with the fuel burning heaters if you haven't set the timer and you flick them on when you start the engine they help it to warm up really fast.
I know a warm engine helps to reduce wear, but I really don't know if that is all that relevant in modern engines?
I know I sound a bit anti the electric heaters but I jut figure they are so much less useful and not really worth the money... especially when compared to the fuel burning heaters.
Post #204462 22nd Jan 2013 9:25pm
VeeTee
Netherlands
Instead of a core plug heater, I bought a heating element with pump, which is installed in te coolant hose. This heats up the engine more effective because of the pumping action. Cheers, Vincent
MySite
Post #204474 22nd Jan 2013 9:46pm
Martyn668
Hi VeeTee. That link worked yesterday, but doesn’t seem to be working today. Looked a good price - around £130, but I hadn’t got round to translating the page to see what it was! Sweden is probably the place to search for heaters though!
Post #746370 19th Dec 2018 12:36am
Martin
Site Admin
See also https://www.t7design.co.uk/products/heatin...-240v.html which have been discussed on here more recently Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #746377 19th Dec 2018 7:50am
Grenadier
Jason.
Just looked at these kits. Can you rig them to a converter and supplementary battery? How much juice do they use during warm up?
For those who've mentioned cabin heating, now mine's insulated (Silent Coat and HD foam), and being a smaller DC cabin, it gets roasty hot once the engine is warm, whatever the outside air temp. Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #746395 19th Dec 2018 11:43am
Martin
Site Admin
2.2kW from a 12V battery is over 180 Amps....
Better to fit a diesel pre heater if you need to unplug Whistle  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #746401 19th Dec 2018 12:34pm
Grenadier
Okaaaay Whistle
Not electrically minded, me!!
Are the T7 kits any good Martin? Just looking at their site. Monsieur Le Grenadier
Post #746402 19th Dec 2018 12:36pm
Martin
Site Admin
Dad's got one on his 110 and it gets used every day during the winter (ski bus)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #746403 19th Dec 2018 12:36pm
Grenadier
Ta. Due to be in the SW in Jan, will pop in to T7 for a chat.... Monsieur Le Grenadier
Post #746406 19th Dec 2018 12:46pm
