![]() | Home > Wheels & Tyres > Mantec Wheel Carrier + Larger Wheels & Tyres |
| Thor Member Since: 17 Dec 2011 Location: Didcot Posts: 446
I THINK mine is a Mantec one (on there when I bought it and no stickers or markings that I've noticed) and I have an 18inch silverline alloy on mine with a 285 tyre. I don't have any issues with it.
Not a massive help as not sure what mine is sorry. Strong people are harder to kill and generally more useful! |
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
Ok,
285/65r18 converted into imperial is: 32.5 x 11 235/85/16 converted into imperial is: 31.7 x 9.3 That means your tire size is less than 1/2 an inch bigger. and less than 1 inch wider (remember only one side of the tire counts). So....... Yes, it will fit VERY easily..... if I have made a calculation error it is because I have been awake for far too long Glyn |
Thor.... basically it is the two different ways of measuring tire sizes.
So for your tires you can call it either: Metric (285/65r18): 285 is the width of the tread in mm 65 is the aspect of the side-wall to the width- so 65% of 285mm 18 is the wheel size in inches. Imperial (32.5x11r18) 32.5 is the diameter of the outer edge of the tire in inches (basically the overall height of the tire). 11 is the width of the tread in inches. 18 is the wheel size in inches. I always find it easier to convert into imperial because it actualy give you real figures that matter- overall diameter and width rather than aspect raios etc. Every day is a school day Glyn |
| Mr B Member Since: 10 Jul 2012 Location: Buckinghamshire Posts: 33
Thanks guys! I'll be ordering tomorrow! Nath
Ah ok. I'm kind of with you, i think cheers.
Seriously thinking about swapping the Silverlines anyway as inreally like the ZUs or at least getting the silverlines powder coated or something. Not sure yet. Strong people are harder to kill and generally more useful! |
| Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670
Just remember to order the spacer kit as well for the carrier, the one i fitted a few weeks ago didnt come with any spacers and there was no chance a standard boost would fit on, i rang mantec and they told me about the spacers so i just made some out of stainless bar so i wouldnt have any rust problems in the future.
Pete. |
Hi Pete, So is this 'spacer kit' literally a sleeve to push the wheel out further? Where abouts does it fit in on the carrier too? Thanks for the tip! Nath |
Basically yes thats all it does, let me see if i can find a picture for you. Pete. |
Click image to enlarge Click image to enlarge Thats just the spacer, you then fit the big thin nut that was on your original land rover wheel carrier. Pete. |
I remember this problem. When my friend fitted one he just got 3 normal LR steel wheel nuts and put them on- spaced it out just right for 255/85s on deep dish alloys.
Glyn |
Pete / Glyn,
Thank you to you both! Nath |
