Home > Td5 > Low range - lack of response?
excossack
I don't often use low box other than reversing trailers or slow crawling.
What should acceleration feel like when low range is engaged?
The reason I ask is, when I tried it the other day, it felt there was no acceleration or a lack of power unless the engine is reved - hard to describe.
I drove a mates ex v8 110 (Santana box) but now a 300tdi off road around his back garden, up and down the terraces and low box felt more responsive - unlike the TD5
Am I expecting more from low box or is this normal. ? I need another TD5 to try and see what that is like, 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #203434 19th Jan 2013 9:00pm
When you select low range, a switch in the t/box changes the characteristics of the throttle pedal.
Not much happens for about 80% of the travel then the last 20% will rev the engine.
Think it was designed for folk who can't 'lock' their ankles whilst bouncing around rough terrain and thus get kangarooing
There's a plug on the t/box you can unplug to stop it....I have on mine; much nicer.
Post #203439 19th Jan 2013 9:12pm
excossack
Cheers, yea that about sums it up, 80% nothing then life!
Will have a look. Is this plug easy identifiable from underneath the car ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #203444 19th Jan 2013 9:17pm
The switch is in the casting on the top of the t/box where the hi-low lever goes into:
Image from Ashcrofts; see the red plastic plug? it goes in there, and has a few inches of cable and a moulded (grey I think) plug on it. which plugs into the vehicle harness.
If you do unplug it, cover both ends in gaffer tape, just to keep the crud out of the pins.
Post #203490 20th Jan 2013 9:08am
ashtrans
Site Sponsor
Hi
The red plug is actually the breather,
I will try to post up a photo of the high/low switch tomorrow,
Dave Dave
Post #203715 20th Jan 2013 9:50pm
D'OH!!!! You're right (of course) Dave... whoops! Embarassed Embarassed
Well, it's in a similar area of the box, more down on the main casting IIRC, with the flylead and plug. Whistle
Post #203773 21st Jan 2013 7:24am
ashtrans
Site Sponsor
this one :
Dave
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Dave
Post #205449 26th Jan 2013 9:18am
excossack
Thanks Dave, that gives me a good idea.
Cheers for your assistance & everyone else. 1999 Defender TD5 110
Regards
John M0VAZ
Post #205457 26th Jan 2013 9:55am
