Home > Off Topic > Ouch! That must've hurt!
Post #203174 18th Jan 2013 10:29pm
Laurie
Good example of misuse of a KERR.
I've seen a lot worse than that.
Post #203177 18th Jan 2013 10:34pm
Lou Sparts
KERR,s should be banned from sale. 2005 Td5 90 XS
Steve
Post #203180 18th Jan 2013 10:39pm
leeds
WHY?
You can not account for complete IDIOTS.
First idiot was the one who drove off the beach into the sea/lake. It is difficult to actually KNOW what the beach is doing underwater. It could have changed gradient suddenly meaning that the vehicle could roll if change of beach gradient was sudden and steep.
The driver (second idiot) doing the 'recovery' obviously was unaware of how to do a recovery OR the strength of his 'recovery point' He also actually drove over the rope!
Idiots number 3 and 4 were standing too close and hence in the 'danger zone'
Alternatives? Use a tow strap? Polyester ? Smaller extensions and if used in that scenario the way they use the rope then HIGHER forces will be generated! Hence even more DANGEROUS!
Nylon recovery straps?
Winch?
IF you look at the video the extension of the rope does not appear to be a good 20% which I would expect from a proper Kinetic Energy Recovery Rope. Also if you look at the rope at the end of the video it appears to be a 3 strand rope. KERR tends to be plaited nylon rope.
A KERR
What ever recovery technique used on 4x4 you can find examples of dangerous practices on Utube etc.
OFFICIAL instructions on use of KERR can be found HERE Yes they say should only be used by TRAINED personnel and not on SOFT SKIN vehicles.
Do NOT blame the equipment when it is used in the hands of idiots!
Learn the differences between different equipment used in recoveries. Learn how to do it safely.
Finally keep all unnecessary people out of the danger zone.
Brendan
Post #203205 18th Jan 2013 11:41pm
+1 ^^^
Definately not the KERR's fault... it didn't break, the bumper came off!
Post #203243 19th Jan 2013 9:49am
reminds me of the Aussie woman who was killed by a towbar the flew thru her windscreen whilst trying to recover someone
Post #203245 19th Jan 2013 9:55am
leeds
I repeat looking at the video it does not appear to be a KERR.
To me it appears to be a 3 strand rope. Next question would be what material is it made off?
Could anyone get a still photo off that video so we could see clearly if that rope is a KERR or a 3 strand rope.
Brendan
Post #203258 19th Jan 2013 10:59am
landy andy
Does not look like a KERR to me, as there's not much give on the first couple of snatches.
Andy
Post #203259 19th Jan 2013 11:04am
fekete
Let that be a lesson to them all Whistle NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #203322 19th Jan 2013 2:53pm
leeds wrote:
WHY?
Because most of us don't have armoured vehicles?
If you extend the off-road maxim "as slow as possible as fast as necessary" (or words to that effect) to recovery then you would use a "dead" rope, taking up the slack first and if that did not work move on to linking a couple of vehicles or winching.
Would be interesting to know the peak loads imparted by the average KERR or snatch technique.
Post #203328 19th Jan 2013 3:28pm
leeds
Nor are the majority of people trained in winching or recovery techniques.
Peak Force or Energy?
Peak force can be calculated from
Force = Mass x Acceleration.
OK in this case technically deaccceleration
Mass in this case is the mass of the vehicle doing the recovery.
Lets look at some 'hand waving' examples.
The vehicle mass is constant.
Lets say free length of the rope/strap/chain etc is the same at say 10 metres.
Lets say have 2 metres of slack in the rope and the vehicle always has the same speed of v metres/sec when it has taken up the slack.
Once the slack is taken up then the (de)acceleration is worked out from the time taken from going from v m/sec down to 0m/sec
This time is dependent on the stretch in the rope/strap etc.
A KERR might stretch 20% whereas a polyester strap 5% and a chain might stretch say 2%.
The (de) acceleration of the KERR is one quarter that of the polyester strap so the peak force would be one quarter of that of the polyester strap and 1/10th of the chain.
In a given snatch recovery situation then the extensibility of the rope/strap is a controlling influence over peak forces generated.
What force was required to extract that vehicle?
OK say stuck vehicle weighs 1500 kg, soft wet sand would have a factor of 4 so force required there would be 375 kg
Assume gradient is zero so no factor there.
Assume that front wheels are bogged to tyre wall height Then you would need a force of 100% of 1500 kg to overcome mire resistance or 1,500 kg.
To recover that stuck vehicle would require a force of 1,875 kg,
That bumper that flew could not take that force, so flew off. i.e. it was not very strong.
To quote billyvista
Quote:
This is a critical step in both the conduct of a winch recovery (because you need to be absolutely sure that EVERY single piece of equipment used in the task is strong enough and will not fail and thereby endanger life and limb), and in the selection/purchase and decision to use a piece of recovery equipment. I
To recover that vehicle using a 'dead' rope technique then the controlling factor would be traction being achieved by the towing vehicle. This then depends on the strength of the ground under the tyres. Being wet sand it is not particularly strong, so it is highly probable that the towing vehicle would just dig it so in. So multiple vehicles linked together?
Or extra long straps? Would they know how to join straps together safely?
Brendan
Post #203387 19th Jan 2013 6:47pm
