![]() | Home > Td5 > What gearbox oil 2000 TD5 main gearbox ATF or MTF94? |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2681 ![]() ![]() ![]() |
assuming ir's an R380 box, it should be MTF94 - LR issued an advisory around 2002 that MTF should be used on the R380's...
IIRC MTF94 is supposed to ease a problem of 1st to 2nd gear shifts when cold. However MTF94 is now the recommended oil for all R380's. Or this if you fancy it (some swear by it) http://shop.difflock.com/difflock-evolutio...-p-51.html Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
BTW - the Part # for a 5-litre can is STC9157
I dfound it cheaper to buy from my local (Pentlands, Edinburgh) dealer (and ask for a good-customer-discount)... ![]() ![]() And here's the advisory from LR: Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 ![]() ![]() |
In my old td5 disco it was ATF as it was a r380q box but could be wrong
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6709 ![]() ![]() ![]() |
It's not ATF in ANY R380, the Q refers to the transfer box and that isn't ATF either.
Don't use ATF in an R380, use MTF :) ![]() ![]() |
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 ![]() ![]() ![]() |
My manual states ATF too but when I changed the oils I used MTF 94. A big improvement in the gear change since doing so.
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 ![]() ![]() ![]() |
Personally I opted for this ( for the gearbox)
Fuchs TITAN SINTOFLUID SAE 75W-80 synthetic manual transmission fluid It is the same spec as the evolution oils but better price. About £40 to change Available from opie oils Very impressed at the improvement I got in a gearbox that has done 200000 miles Plan to change it every 2 years Silky smooth now when it was notchy especially when cold before ![]() |
totalal Member Since: 26 Dec 2012 Location: Pembroke Posts: 36 ![]() ![]() ![]() |
EMPI748 Member Since: 15 Dec 2012 Location: Penicuik, Midlothian Posts: 50 ![]() ![]() ![]() |
Thanks for the replies will go with the MTF-94.
I was thinking of using Smith and Allan's oil, used it in the 6 speed box in my laguna (although different spec) and it totally transformed it, seems a decent price too. |
Riverblanche Member Since: 12 Sep 2012 Location: Retfordish Posts: 34 ![]() ![]() |
Hi,
Changed the oil in my D2 gearbox R380 couple of weeks back MTF-94 paid just over £7/litre to give you a guide price. Dropped 2.2 litres and put 2.5 back in to get to the level plug Just make sure you can un-do the level plug before you drop the oil if you do an oil change ![]() ![]() |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 ![]() ![]() ![]() |
Thank you for saying this, so many people forget to do this. ALWAYS START AT THE FILLER/LEVEL PLUG FIRST, then Drain plug. After all, you can at least top it up, even if you cant get the drain out... |
