Home > For Sale & Wanted > Wanted: 110 DCB Pick Up Canopy
TTF
Looking for a truckman style canopy for a 110 double cab.
Ifor Williams or canvas style won't work as need it to be secure & dry for tools etc!
Post #200755 11th Jan 2013 10:07am
Post #200771 11th Jan 2013 11:19am
Re: Wanted: 110 DCB Pick Up Canopy
FWIW I use an IW (with solid flap) on mine and it is entirely satisfactory in terms of dryness and security for tools etc.
Post #200784 11th Jan 2013 12:03pm
TTF
Pictures look good - is that an IFW option or home design/build?
Post #200794 11th Jan 2013 12:45pm
Standard IW. The solid flap is simply an optional alternative to the "meshgate" suipplied as standard. There is also a solid flap with a window if you prefer.
The only thing that I have found is that there is a gap of about 1/2" between the bottom of the flaps and the "gunwhale" of the rear body/tailgate. You do get a certain amount of fine spray drawn in when driving on really wet roads. However there are alternative rubber seal strips available from some of the kit-car/restoration suppliers that could replace the IW rubber and cover this gap - I've simply never got around to fitting one. All I do on a wet day is put an old blanket over whatever's in the back.
Post #200798 11th Jan 2013 1:02pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
I built this. It's still not finished, but should be pretty secure and dry, just needs a rear cat-flap or door fitting.
Post #200839 11th Jan 2013 3:55pm
