Home > Maintenance & Modifications > Defender plus Sankey trailer - how to mount NATO hitch |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 |
In short........ It will be too low.
I believe a few people have got 2 Dixon bate adaptors, one with 50mm ball and the other with a NATO hitch- just change around for what is needed. Other option would be to lower the A bar on the trailer. I have got a seperate plate that bolts to my NAS rear step (brings it up to cross member height). Glyn |
9th Jan 2013 9:43pm |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
Mine is on a spare slider. I have a LR Dixon Bate adjustable tow bar and with the slider fitted up high it was fine with my old narrow track Sankey.
I found that the previously fitted NAS type step was a bit low. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
9th Jan 2013 9:54pm |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 |
The spreader plate goes between the cross member and the hitch. Side loading the hitch buckling the cross member is the issue.
Instead of a spreader plate I have a reciever hitch which would normally use all 6 holes on the cross member to mount it. My hitch is therefore mounted at the proper height but also braced to the chassis. Plus the added befit of being able to tow normal trailer and increase the departure angle. |
9th Jan 2013 9:56pm |
VeeTee Member Since: 06 Mar 2011 Location: Somewhere Posts: 1512 |
Hey, that's a nice lid on your trailer Click image to enlarge I changed the Nato hitch to a towing ball configuration, the legal status and insurance of the Nato hitch and eye are debatable here in the Netherlands. I lowered the A frame on the trailer for the correct height. Also made it a bit longer, this is easier for reversing. Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
9th Jan 2013 10:28pm |
This solution works for me - Dixon Bate adjustable tow bar with NATO hitch bolted to a standard slider:
Click image to enlarge At this height the trailer is nice and level: Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
9th Jan 2013 10:41pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16894 |
I use the same set-up as Darren, it works perfectly.
I have a NATO pintle on one slider, a DB combined 25mm pin/50mm ball 3.5 ton coupling on another, DB 32mm pin 5-ton (four bolt) coupling on a third, covers all my towing requirements and the sliders are interchangeable between the Disco2 and the Defender. The latest coupling I bought to try out is a Bradley/DB Autojaw, which works pretty well provided that you align the thing perfectly when reversing into the trailer (easy with 2 people but not so easy on your own, which kind of defeats the whole point)! |
10th Jan 2013 10:45am |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Same here. My Viking MkIII sits level on the top hole.
10th Jan 2013 2:09pm |
nihwrd Member Since: 12 Apr 2012 Location: Somerset Posts: 28 |
All
thanks for useful advice and PMs. I think I've spotted where my problem lies (but can't work out how to post photos). The LR Accessories web site shows p/n LR007221 (the adjustable tow bar for a 90) with a longer slider support than mine has fitted. A quick visit to Yeovil Land Rover to see what's what is in order I think. If I can get a longer slider support, I'm pretty sure I'll go for the second slider/NATO hitch option, so if anyone has one they don't want anymore, please PM me. Nick |
10th Jan 2013 2:19pm |
I have a slider unit that is shorter where it meets the cross member. I know why mine is short, it's because it was a Discovery part not a Defender part, I'll change mine when I come across one........one day.
10th Jan 2013 3:52pm |
