Home > Maintenance & Modifications > wiring diagram for rear wiper switch as aux switch |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6041 |
Looking at the Rave diagram, Pin 1 is Earth, pin 4 is the live (via whatever you're trying to switch)
The wiper motor is "live" via the ignition, and switched to earth through the dash switch. If you were to wire it the other way round just as a normal switch, you'll find that the warning light on it won't work properly. It's not a problem though... take the power feed for your spotlight relay (fused, naturally), through the coil of the relay, then to the switch (pin 4) then to earth (pin 1) and it should work just as the rear wiper did. Click image to enlarge Click image to enlarge |
7th Jan 2013 7:25pm |
mattlab Member Since: 16 May 2011 Location: suffolk Posts: 143 |
thanks jim, much appreciated.
matt. LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE |
7th Jan 2013 8:52pm |
