![]() | Home > Technical > Seat pan inspection cover. |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 ![]() ![]() ![]() |
(08 90 Puma.) Take off the cubby box. Roll back the carpet and there is a steel plate inspection cover that holds the riv-nuts for the cubby box. Mine is corroding and I'd like to replace it but LR inform me I have to buy the whole seat pan unit to get this small part.
Anyone know where I can get it else where? |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967 ![]() ![]() |
Cant you refinish it
I can if I have to. If I can order the part cheaply and quickly enough Id do that first. Not lazy just busy.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
Never said you were... I can't see why LR can't supply them individually anyway all the same. That said if they did it would probably be extremely over priced. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
They often come up on EBay ...
I've taken it to the shed and cleaned it up. Horrible amount of bi-metal corrosion there though. Trucks vertually new! Needs new screws and some gasket between the two metals of it and the ali floorpan. Oh well, another job done.
