Home > Wheels & Tyres > Mountain/snowflake rated tyres
John.L
Afternoon all,
Has anyone here got a list of which standard size all terrain tyres are mountain/ snowflake rated? I am after a set of 235/85R16 tyres that fit wolf rims or 7.5/16 for the standard steel wheels.
Cheers,
John
Post #198899 4th Jan 2013 2:42pm
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
2012 list of approved tyres:
http://www.stro.se/winter/vinter101001e.pdf
Jason.
Post #198907 4th Jan 2013 3:15pm
macduff
Nokian Rotiiva AT 235/85 R16 120/116R listed on mytyres.co.uk http://www.mytyres.co.uk/cgi-bin/rshop.pl?...p;dsco=110 appear to have a snowflake symbol even though they are listed as a summer tyre?
and GT Radial Maxmiler WT 1000 235/85 R16 120/116 Q listed on Oponeo http://www.oponeo.co.uk/tyre-details/gt-ra...-120-116-q also appear to be a winter tyre, dont know if they have a snowflake symbol or just M+S.
PS I have no views on these and just stumled across them when looking for tyre options for my 110. 2023 110 P400e
Post #198913 4th Jan 2013 3:26pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
BF Goodrich AT tyres all year round.....cant go wrong with them. BM52
Post #198925 4th Jan 2013 4:44pm
jasong4110
I just brought a set of General Grabber AT2's they were a great price @ £120 per corner delivered.
Jason.
Post #198929 4th Jan 2013 5:06pm
ericvv
These Nokian winter tires are recommended/offered by Land Rover Switzerland as winter tires for the Defender. I have those for 4 years now on black modulars and can confirm they are very good, also suitable for light off-roading.
http://www.nokiantires.com/tyre?id=11879&group=2 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #198933 4th Jan 2013 5:29pm
John.L
Thanks for the quick replies!
The PDF list appeared to cover M+S rated tyres rather than those with the mountain/snowflake symbol. In my experience, these are usually far worse in real winter conditions.
Are the BFG AT's mountain/snowflake rated? I am sure the ones I looked at just had the M+S mark.
The Nokian tyres mentioned seem to be a summer tyre and are probably the wrong rubber compound (to hard) for cold, winter conditions. Nokian do not currently sell a real all terrain winter tyre, their most suitable for the Defender appears to be their LT range (light truck).
Ideally, I'd like a winter tyre that would also work reasonably well off road, in fields etc.
Thanks again for your help!
Post #198939 4th Jan 2013 5:39pm
macduff
Just checked the Nokian site and the rotiva AT is an all weather tyre listed for severe winters
http://www.nokiantires.com/tyre?id=132374&...%20Rotiiva AT
snippets
"Extremely stable tire with high performance on and off the road
Aggressive tread pattern guarantees exceptional handling
Sturdy cut-resistant tread surface
Severe Service Emblem or Mountain Snowflake Symbol designation rated for use in severe winter conditions
The aggressive tread pattern of the new product, and especially its wide, polished grooves maximize grip and handling in rapidly changing summer conditions. Thanks to a unique tread pattern, the tire also cleans easily and runs effortlessly in winter conditions."
And its an AT too... not sure you'll find any MT tyres with a snowflake rating. 2023 110 P400e
Post #198957 4th Jan 2013 6:34pm
BFG KOs in 265.75.16 & 285.75.16 are def mountain snowflake that list is out of date
235.85.16 is also listed as mountain snowflake Thumbs Up
Post #198961 4th Jan 2013 6:40pm
Ken - not that much out of date, the document has "Updated: 2012-10-01" but it's a Swedish list
Post #198964 4th Jan 2013 6:49pm
I'll try that with our suppliers price list Rolling with laughter
Post #198966 4th Jan 2013 6:50pm
Winter Tyres are in Norway and Sweden defined as: ”Tyres specially design for winter use AND
marked M+S, M.S., M&S, M-S, MS or 'Mud and Snow”. The list below is a list of tyres witch by the
tyre producers are defined as specially designed for winter use. This is in line with the demands from
the Norwegian and Swedish authorities. The list is based on information from the tyre importer and
STRO have no responsibility for the accuracy of the information.
Post #198973 4th Jan 2013 7:02pm
dgardel
Italy
General Grabber AT2
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #198974 4th Jan 2013 7:04pm
John.L
Excellent, good stuff thanks!
So, looks like it'll be the Nokians or BFG's, both look good.
Have a good weekend, cheers, John
Post #198977 4th Jan 2013 7:05pm
Depends on what you want
Nokians are highly regarded as WINTER tyres way way way up there
BFG ALthough they are mountain snowflake rated they are not as soft nor have as many sipes so they are a good al round tyre but when the going gets tricky the Nokians will have the edge
Note these tyres are Winter / Cold weather tyres not true snow tyres and thats a whole new discussion best left to the guys who have snow rather than our cold weather Thumbs Up
Post #198992 4th Jan 2013 8:24pm
