Home > For Sale & Wanted > Wanted speedo housing
landyman37
Hi I am looking for a speedo drive to fit onto my r380 gearbox the one that is on does not have the transducer for the electronic speedo.
Any one out there got one.
Phil
Post #197349 29th Dec 2012 9:25pm
jst
you mean the T box?
all the drives take either a cable or the transducer.
if you want a td5 speedo then all you need is the 3 wire transducer to fit into the existing speedo drive in the side of the transfer box. they are about £20 ish. Bearmach do replacement parts. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #197364 29th Dec 2012 10:02pm
landyman37
James
The transfer box that is fitted has neither the gearbox came out of a discovery II has any oe else came across this.
Phil
Post #197367 29th Dec 2012 10:06pm
jst
oh, ok. i know it a different transducer in a disco 2 - a 2 wire one. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #197371 29th Dec 2012 10:08pm
Retroanaconda
If it's to run the Td5 speedo then you want the YBE100530 part.
Do not buy an aftermarket one, I have yet to hear of one reading correctly! Genuine ones are not that expensive (see above link).
Post #197373 29th Dec 2012 10:12pm
landyman37
I need it to run a tdci speedo
Phil
Post #197375 29th Dec 2012 10:14pm
Retroanaconda
No idea then really.
What vehicle do you have? What is the situation (ie. replacing gearbox)?
An R380 is to fit 300Tdi/Td5 vehicles, not Tdci.
Post #197377 29th Dec 2012 10:18pm
landyman37
Hi I have fitted a td5 engine and gearbox into defender 110 crew cab with a tdci bulk head. The rear of the transfer box as no holes to fit a transducer into so it looks like I need a rear housing.
Phil
Post #197380 29th Dec 2012 10:21pm
Retroanaconda
Ah, well then you're going to have bigger issues.
As of current I am not yet aware of anybody making the Tdci instruments work with Td5 or older vehicles. Most of the dashboard and switchgear works fine, but the speedo and gauges are run very differently than older models. The speedo for example is driven by the ECU (which reads the speed sensor), whereas on a Td5 the speedo reads the sensor directly, and then the ECU reads off the speedo.
I've seen a Land Rover for sale where someone had grafted Td5 gauges into the Tdci dashboard, but it looked a bit odd.
Post #197408 29th Dec 2012 10:55pm
landyman37
If you use the loom for the td5 engine then the plug is already there for the speedo
Post #197501 30th Dec 2012 1:29pm
landyman37
Hi all I have just updated its the complete housing that bolts to the rear of the transfer box.
Phil
Post #197847 31st Dec 2012 5:32pm
