Home > Maintenance & Modifications > What is this sealing tape? - I want some!
Martyn
United Kingdom 2014 Defender 90 Puma 2.2 PU Keswick Green
Under the 2nd row seats in the 110 DCPU, quite a few seams are sealed using an aluminium tape about an inch wide which appears to have a good 1mm thickness of some black "dum-dum" like stuff on it, then a very sticky adhesive coating.
Some of it was fitted at the factory and it was oversprayed with the body. Some was fitted after painting at the factory.
I have had a fair bit pulled off and redone by the stealer under warranty as it leaked like a sieve.
What is this 3-layer tape called and where do I get it?
I have searched on the net a fair bit but not knowing what it is, I'm struggling Rolling Eyes
Tvm, Mart
Post #196949 28th Dec 2012 3:40pm
Laurie
Is it adhesive or thermal application?
Could be worth searching both.
Post #196951 28th Dec 2012 3:48pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
It's probably bitumen/flashing/flashband tape. You can buy it at most DIY stores
Post #196955 28th Dec 2012 4:30pm
Killer90
Site Sponsor
you could try dynatape, or failing this hostage/duck tape works a treat Thumbs Up Thumbs Up CSK Automotive
www.cskautomotive.co.uk
Post #196959 28th Dec 2012 4:49pm
