Home > Technical > Anti roll bar yep/no
Ric
What's your thoughts on removing the anti roll bars, 110 puma
I was advised too remove them for green laning, giving more axle movement, but I don't want to be rolling it over on the bends on the way home Shocked its only a car!
Post #196467 26th Dec 2012 1:24am
Peter
United Kingdom 2005 Defender 90 Td5 SW Epsom Green
Got a feeling x-eng have a solution for this exact requirement.
http://www.x-eng.co.uk/X-Flex.asp
Peter
Post #196471 26th Dec 2012 3:36am
JeremyJ
2nd vote for the x-eng bar. I've run one for a while and it works very very well
Post #196474 26th Dec 2012 7:39am
really depends on how much you go off road, i have ARB on my 90 and take it off road but nothing too technical, but this means on road it's still fine to drive without becoming sea-sick
Post #196475 26th Dec 2012 7:44am
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Hi, I have taken the anti roll bars off of my 90 and while it does have some body roll in the bends I have not had it on 2 wheels yet and I have tried. I drive very quickly on the roads out here and the most I have had happen so far is a four wheel drift. I also have a two inch lift.
I think the only time that you are likely to induce a roll over is in an accident type scenario or maybe a very, very hard swerve.
HTH.
Regards,
Mark
Post #196481 26th Dec 2012 9:41am
My 110 DC has never had anti-roll bars and although there is more body roll on corners than on my Disco 2 (no surprises there!) it really isn't a problem, even with a Patriot rack.
I suspect that the springs are stiffer on the 110DC though since it has the 1-ton payload and no arbs as standard.
Post #196482 26th Dec 2012 9:59am
I have ARB's front & back on my 110, and still get around pretty well. Axle travel isn't too bad at all.
Post #196483 26th Dec 2012 10:59am
leeds
Re: Anti roll bar yep/no
WHY? WHY? WHY?
As I understand it you did your first green Laning trip the other day.
Now Defenders are an extremely capable vehicle on road including green lanes (which are legal roads) and off road.
Yes people like to modify their Defenders, but I would suggest you get some more experience under your tyres before opening your wallet too much.
Decent recovery points, a decent 'bit of string' with some good pointers how to use them.
Some basic underbody protection possibly some rock and tree sliders rather then steps as asked on another thread.
We run our Defenders both with and without ARBs. On one broke the rear ARB and have never replaced it. People following us have commented on body roll going into corners but I have not experienced any problems with it.
Get a lot more experience with the vehicle first and then decide how you are mainly using the vehicle and how you NEED to modify it so it fulfils YOUR requirements!
Brendan
Post #196486 26th Dec 2012 11:34am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Also...if you have TC it will pull you through most problems once you get to know how it works and trust it to do the job it is designed to do.
I have a 90 so slightly different and I mostly do roads and i have a stiffer rear ARB but it has not affected the off road ability on any part of a LR Experience course. it might do if you go extreme but i would have thought normal green lanes would be fine with an ARB fitted. Can I suggest you take Leeds advice he is extremely experienced as are many others on this site. Me....I am just a keen novice when compare to Leeds. BM52
Post #196489 26th Dec 2012 12:09pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
I had both on my 90 and took them off to go rock climbing and it really helps keep the tyres down. However. I was followed by a mate on road who said it looked like a boat even though it felt fine, so I put the front back in and i gained up to 10mph on certain fast corners and off road I have possibly lost half an inch of flex if that when climbing or not enough to really make a difference. Rhubarb and custard let fly with their secret weapon.
Post #196493 26th Dec 2012 12:57pm
Ric
Right, thanks all for the comments and tips.
Leeds wrote:
"WHY? WHY? WHY?"
That's why I asked, it was just spoke about and I wondered about the pros & cons
"As I understand it you did your first green Laning trip the other day."
This is true, and hence the post
"Yes people like to modify their Defenders, but I would suggest you get some more experience under your tyres before opening your wallet too much."
I was just referring to the removal of the anti roll bars, nothing more, so no cost!
I'm in favour if keeping them, however just wanted to hear other opinions
"Decent recovery points, a decent 'bit of string' with some good pointers how to use them"
Thanks
"Some basic underbody protection possibly some rock and tree sliders rather then steps as asked on another thread"
Hrmm, this is confusing, maybe I wrote that post wrong. I have steps on as standard, the thread was about replacing them with rock / tree sliders. As for the rest of underbody protection, this is what I've been sensibly opening my wallet for, the only luxury bit was the entreq trans/fuel cooler guard that we spoke about (pm was sent)
Brendan, thanks for the tips, looking forward to the trip over as discussed and regards above, just defending my corner Wink its only a car!
Post #196659 27th Dec 2012 12:17pm
Dave-H
I fitted front and rear ARB's to my 90 about 3 years ago to firm it up a bit on the road
i've not noticed any difference whatsoever in it off road abilities .. still goes everywhere i point it... and we do some pretty serious laning at times Cool
Dont remove yours thinking it will make a vast improvement in its off road ability .... i doubt you'll notice any difference other than on tarmac Rolling Eyes Guns and Landrovers .... anything else is irrelevant.
Post #196680 27th Dec 2012 4:02pm
Pam W
England 1998 Defender 90 Td5 SW Auto Oslo Blue
I refuse to call them ARBs as that means something completely different to me! In serious off-roading circles 'front and rear ARBs' would be interpreted as 'front and rear ARB diff lockers'.... Rolling Eyes Wink Very Happy
Anyway, I have never had anti-roll bars on my Defender. Never had them, never missed them, never had noticeable or worrying body roll. I drive my vehicle properly as it should be driven for a high centre of gravity vehicle. \
I used to have my springs and shocks set-up designed for mainly road use, nice and stiff, but it also had reasonable articulation off-road. There is quite a big difference now I've got longer springs and longer travel shocks on, so I've had to learn to anticipate this on bends and reduce speed accordingly - although it still holds the road really well, it 'feels' a lot more body roll - but actually it is still pretty stable...
Changing (renewing or changing to different) shocks and springs is likely, on most Defenders, to make more difference to the feel of the whole vehicle - ie. comfort and road-holding, than adding or removing anti-roll bars.
The thing to remember is that the 'roll' bit in anti-roll' refers to anti-body roll, not anti-roll-over. Stiffening the body roll will, to some extent, reduce the 'flip-flop' effect if the vehicle gets out of sorts, or will put it into less of a lean on bends, so slightly lessening the risk of lifting the wheels on the other side.... but the best thing is, as I said above, to drive in a manner that doesn't get you into those situations!
Thumbs Up Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net
Post #196729 27th Dec 2012 5:51pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
Driven mine without for a month, but put mine back on.
Mainly because i couldnt see any difference offroad, but i found it alot nicer to drive on roads 2004 TD5 Defender 90 xs station wagon
Post #196811 27th Dec 2012 8:44pm
pannawonica
Australia
ARB's, AKA air leakers as they are know as over here. Took me a little while to work out what you were on about! Rolling with laughter Happy new year. Thumbs Up
Post #196924 28th Dec 2012 11:58am
