Home > In Car Electronics > Installing active subwoofer connections
Brucey
Poland 2004 Defender 110 Td5 DCPU Auto Java Black
Hi There
May be dopey question time, but I am a bit foxed.
My head unit has 'Low level' output via L and R RCA output.
My Active Subwoofer has two RCA inputs High and Low.....Can I just connect? doesn't seem logical.
Any suggestions welcome!
Chris Defender 110 DC converted Auto
BMW R1200GS
BMW F650GS Dakar
Post #195698 22nd Dec 2012 4:30pm
Head Unit Low level is it's output.
Sub input Low or High.
You should be fine to just connect up. Basically means your active Sub can take either but your HU is Low level which will work no probs.
Thumbs Up
*EDIT*
Same situation for me with my HU and Amp. HU is Low level output and Amp can take either Low or High in-put. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #195717 22nd Dec 2012 5:25pm
Brucey
OK, thanks.
I was concerned that I will only get half of any signal. i.e the Low level of 'say' left channel and High level of Right Channel.
Where would you set the crossover? Circa 100Hz?
BMW R1200GS
BMW F650GS Dakar
Post #195721 22nd Dec 2012 5:39pm
Chris
I can do that on my HU so maybe yours has the feature / option to do the same? (May depend on Brand, Model and features and so on.
What active sub did you buy may I ask? ____\We|Will|Win/___
Post #195726 22nd Dec 2012 6:06pm
Brucey
Cheapest that I could get off the shelf!!
Peiying PY-NB3000 Active Car Audio Subwoofer
I have an old Pioneer DEH P2600 HU with Multi Changer that I used to have in my RR a long (and better off) time ago.
It is only recently that I have started to upgrade bits on my Defender, and this Subwoofer was in a sale here so...
It seems illogical to me to connect LHS low level output to High level input on the subwoofer and RHS Low level output to the Low level input....but this is what I am looking at doing.
C Defender 110 DC converted Auto
BMW R1200GS
BMW F650GS Dakar
Post #195729 22nd Dec 2012 6:19pm
I see what your saying but I don't quite know why that would be... They should match and be either high or low only. Confused ____\We|Will|Win/___
Post #195736 22nd Dec 2012 6:39pm
Brucey
Well, that was the reason for my original query.
The two RCA sockets on the HU are 'Low output' Left and Right.
The Subwoofer does not have Left and Right (as there is only one!) but has two RCA sockets High and Low.
Hence I bought a two plug RCA cable (without reading the manual!) and am now a bit flummoxed! Embarassed
BMW R1200GS
BMW F650GS Dakar
Post #195737 22nd Dec 2012 6:46pm
mk1collector
If the HU has a left and right low output and the sub only has one low input you can get an RCA lead that goes from two male to one female end the just put a single RCA lead from that to the sub and you will get the two sides ie left and right signals Thumbs Up
Post #195766 22nd Dec 2012 7:44pm
Brucey
OK! When I went to the shop, they had a two to one cable as described above even called a 'subwoofer adapter' so, problem solved.
Thanks all for your input and Happy Christmas to all!
BMW R1200GS
BMW F650GS Dakar
Post #196000 23rd Dec 2012 3:37pm
Great news. Thumbs Up ____\We|Will|Win/___
Post #196012 23rd Dec 2012 4:27pm
