Home > Maintenance & Modifications > Evans Cooling Fluid
Naks
Evans Cooling Fluid
Hi gents,
Colleague of mine just swapped the coolant in his souped up Fiesta ST for Evans Cooling Fluid (http://www.evanscooling.co.za/products.html) and reports drops in temp of around 6-8C at peak temperature.
Also, at peak temps, you can take the cap off the radiator and there is no pressure and the coolant is not boiling, you can even dip your finger in it.
I'm swapping the OEM intercooler for the Allisport one on Monday, and thinking I may as well swap the coolant. Total cost is around R1k for the prep fluid and the actual coolant.
Has anyone tried this in a landy?
Pros/cons? --
Post #193388 14th Dec 2012 8:35am
