Home > Technical > Side light bulbs
Jammer600
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
Side light bulbs
Will these fit ?? eBay Item No. 120755739290 90 Puma HT
Post #193271 13th Dec 2012 9:35pm
Dave-H
Not in a standard front sidelamp no ... led cluster is too wide to fit into lens housing. Guns and Landrovers .... anything else is irrelevant.
Post #193279 13th Dec 2012 9:57pm
Jammer600
But don't people use the led's in the tail/stop lights? What I'm saying is they fit in them don't they? And you on about the diameter of the base of the bulb? Or the glass end? 90 Puma HT
Post #193293 13th Dec 2012 10:20pm
Dave-H
The glass end ... the opening on the back of the lamp [for the bulb holder] is smaller on a sidelight than on the tail light/indicators etc .. so the led part of those bulbs will not fit inside the lamp .. i tried a couple of years ago Confused
You need the smaller cluster versions [9 led] like item eBay Item No. 280866112955 Guns and Landrovers .... anything else is irrelevant.
Post #193310 13th Dec 2012 10:46pm
