![]() | Home > Maintenance & Modifications > bilstein or terra firma |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8486
i use TF on 3 90s all on the rear. they are a good budget shock. i run them as i am prepared to take the knocks on them from off roading and they are cheap to change and do what i need.
i run OMEs or Kings on the front as they are protected in the springs. for heavy towing on the rear i would prob look for something a bit more up market, price allowing, OME etc. on my 110 i put some adjustable air bags inside the rear springs to firm up the ride and that works for me. is it def shocks that are the issue or springs? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472
I have bilstein on standard 90 springs and ok the back will sag to a point but the shocks are fantastic to be honest unladen it's to hard
| farmerfarrow Member Since: 19 Nov 2012 Location: Lincolnshire Posts: 24
dont know for fact, but would say in the springs. never changed one then the other, always done springs and shockers together.
| lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764
I've had some TF on my ex-90....C
Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
OME
Sorry i had mis read your post ref the springs comment.
why not stick with stock and try airbags if your not always running it laden. if its always heavily loaded then go for some HD springs from the likes of OME or Eibach or fit LR HD equivalents? what are you running? 90? i wouldnt bother with changing shocks initially FYI: TF shocks are the same as Procomp ones, manu in same place. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| ClaireWright Member Since: 12 Oct 2012 Location: Warwickshire Posts: 609
Thinki have terrafirma shares lol
Yer it is for a 90, didn't know you could get an air bag conversion. What do they involve and cost. My old mans discovery keeps going wrong, if this makes sence, say you have 3500 kgs behind, of which are cattle, if they all move to the back, the bags re calibrate, then the beast move forward and it goes with a bang and bottoms out, then has to pump up again.
| All times are GMT |
