![]() | Home > Technical > Rear Light connectors |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Is it possible to buy the part which plugs into the standard rear/side/brake lights? They would need to have leads coming from them to connect to wiring on 90, so the plug part with fly lead attached (same as on a 2011 puma).
Reason being I swapped mine out when new for a set of Mobile Centre led ones so I have a set of standard lights cluttering up the garage, and my 1989 90 needs some new ones as a couple are corroded inside, so if I could use them (assuming they fit) it would get them used for something and save having to buy some more. The lights I need to change are the stop/tail ones (at the moment anyway, might just swap the whole set over. Cheers DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6705 ![]() ![]() ![]() |
I'm sure Tim does the connectors
Why didn't I think of that - duh dj 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
Indeed he does...
http://www.mobilecentre.co.uk/index.php?ma...ath=36_212 Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
I'll give Tim a ring on monday then, I'm after the oval shaped ones. Hopefully he'll have some - trouble is he also sells the led headlights as well
![]() DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6214 ![]() ![]() ![]() |
Just find your local automotive place, that supplies Durite stuff.
The 3 pin male "econoseal" plug that LR use is part # 0-012-43, and the female side is 0-012-53. cost about £3 each. Bit of soldering and you're done. Whole catalogue here for the Durite econoseal plugs |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 675 ![]() ![]() |
If you want the proper crimpers, I got mine from here...
http://polevolt.co.uk/acatalog/info_TT351.html Cheers Steve |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 ![]() ![]() ![]() |
Do you need the proper crimpers to do this, or can you make do with another crimping tool?
(I feel a Mighty Boosh sketch coming on here) |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
Would this make life easier
![]() Good man! |
