Home > Technical > munching crunching hi low
Caterham
is it possible (even normal) to be able to go from high to low ratios without crunching the gears?
Post #189514 29th Nov 2012 4:01pm
Andy Jeff
United Kingdom 1999 Defender 90 Td5 CSW Chawton White
Yes if you stop first!
Andy.
Post #189515 29th Nov 2012 4:07pm
Caterham
Bow down
even if you stop do you need to be genius to pull that off ?
or just on different skill level to myself?
Post #189517 29th Nov 2012 4:13pm
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Never done it that way round but I was taught to go from low to high on the fly by double de-clutching, useful when towing very heavy loads.
Post #189518 29th Nov 2012 4:13pm
Caterham
its always amazed me how the heck you can go from low to high when pulling a heavy load without either rolling backwards by the time you've done a smooth change....
or alternatively trashing the box ??
Post #189520 29th Nov 2012 4:15pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
yes here also
noticed that it is not the fact if you are moving or not that makes a huge difference (within limits of course) but the fact if there are forces on your drivetrain (car is accelerating or decelerating) that makes a big difference to me in getting a crunch.
When coasting it is much more gentle. When not moving i most of the time don't mesh (so dont engage completely) and have to drive the gearbox of bit by engaging clutch or getting of the brake so car starts rolling.
Smile
Post #189521 29th Nov 2012 4:19pm
Naks
Re: munching crunching hi low
yes, if you slow down to <15kmh. --
Post #189522 29th Nov 2012 4:21pm
Caterham
Hmmm
I almost don't dare to try.....
Post #189526 29th Nov 2012 4:36pm
You can do either change silently and smoothly provided you know how to change gear properly, in other words were taught to double-declutch and drive with a gearbox without synchromesh. You do of course need to change gear at a suitable speed, and there is the further complication that very often you will be trying to change from (say) low fifth to high second in a single change.
If you are stationary it should be silent and smooth, though it is sometimes necessary to spin the transfer gears in neutral whilst doing so.
Post #189534 29th Nov 2012 5:04pm
Andy Jeff
Caterham wrote:
Bow down
I get what you're saying!
Firstly, I normally only ever change from low to high (or vice-versa) when at a stand still. 50% of the time, it just does it. The other 50%, I have the car in gear and lift the clutch until it does just drop in, and normally never without any crunching. This has always been my personal approach with all Defenders I have owned/driven and coincidentally was how the knowledgable Land Rover Experience instructor showed me how to do it.
Though I remember when teaching my daughter how to drive her Defender, the transfer box would always change without any problem and I was most put out that I couldn't demonstrate the 'knack' which I (and I suspect many others) use.
Andy.
Post #189536 29th Nov 2012 5:10pm
Caterham
hmm.
just gonna pop out and see if its any different following replacement part on transfer box along with the new clutch.....
not quite sure what the dealer was on about but on one hand they were saying the clutch had shattered springs......on the other they were suggesting even so it was ok and didn't need changing (hows that work)?
Post #189644 29th Nov 2012 9:58pm
Caterham
wow.
just popped out and hey presto piece of cake.
can more from hi low and back easily (albeit I was stationary) just as you'd expect (or hope).
so can only assume the new clutch and spline have made a significant difference?
....in fact changed from hi / low so well I'm almost thinking something must be wrong!?
Post #189657 29th Nov 2012 10:10pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
The way things have been going with the gearbox recently it's possible the lever isn't connected Rolling with laughter
I did have a look at one at Nene when I bought my 110 and the h/l lever wasn't connected to anything (I think you'd know though Laughing )
Glad it's working for you Thumbs Up
Dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #189701 30th Nov 2012 12:09am
jst
this was covered a while back but i cant find the thread now.
hi - low is best done at a standstill, engine running with it in gear, clutch in, then as above, use the clutch, whilst applying gentle pressure to the hi/low lever to allow eveything to align. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #189830 30th Nov 2012 5:42pm
Caterham
hmm in gear. I thought in was supposed to be in neutral (oops - shows what I know)
Post #189843 30th Nov 2012 6:03pm
