![]() | Home > Technical > Heat protective sleeve |
http://uk.farnell.com/?CMP=KNC-GUK-FUK-GEN-PFB&mckv=sRTVHN5s7|pcrid|13360955229|kword|farnell|match|e|plid|&utm_expid=61856916-4&utm_referrer=http%3A%2F%2Fwww.google.co.uk%2F
http://uk.rs-online.com/web/?cm_mmc=UK-PPC...tAod_VAAHQ If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Dyneema/Plasma are UHMWE polyethylene which will have a melting point of about 120C. However the strength of UHMWPE will start dropping off sharply from about 70C.
Now best heat insulation will be given by glass or kevlar type tubular webbing. Give Andy at Ruftraks a ring on 07806-776311 or David at Bowyers (0)1363 82666 There again good old nylon tubular webbing is better then nothing. Brendan |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
David Bowyer is as much use as a chocolate teacup in the desert.
120 or even 70 degrees isn't really enough for a braked winch drum, 300 degrees is where I want to protect. I'm fortunate to know a bit about this, it's more finding the place that sells the stuff in the uk...Canada I'm sorted. Mike |
This is the sort of stuff I'm trying to find
![]() Click image to enlarge Resists temps of upto 370 C Mike |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
That looks like the glass fibre sleeving we used to use on heater bands to protect the wiring..
Cobs has given you one lead also try Fothergill Engineering Textiles. If they want you to buy large quantities it might be worthwhile talking to a good electrical whoesalers and see what they can source. Brendan |
That is the one perfect thanks - ill give them a call... Mike |
All ordered - protection up to 600C!
thanks Mike |
