![]() | Home > Maintenance & Modifications > X-Tech Sound Proofing |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 ![]() ![]() ![]() |
Sound Prooofed the floor,
No wonder they leak no seals on tie downs ![]() ![]() Do seem to have spayde some sort of protection under wings on the 2.2 ![]() Dynamat in, expensive though this cost 0ver 100 quid ![]() ![]() Fitted sound proffing that came with the Mud Panels ![]() Fitted side panels would be best to do this first due to the amount of swarf generated. ![]() ![]() Mask off round the tub seal and used gutter sealant ![]() ![]() Next is wood floor and T Chest. Original Member Pie n Pea Club. 110 HCPU Tipper |
Nice
Waldo Member Since: 18 Jul 2010 Location: Bit South of Manchester Posts: 240 ![]() ![]() |
Gorgeous, top job
May I ask what gutter sealant you used?? Defender 90 XS TD5 (03 Reg) |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
top job mate done properly
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
Why use gutter sealant?
Thank you |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2034 ![]() ![]() |
Looks like what I did in mine over the spring and summer.
In hindsight the MUD panels could do with a double thickness of foam in the side panel recesses, as once fitted there is a little give in them. 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
And was it worth it? is it whisper quiet inside now? |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 ![]() ![]() ![]() |
Well done Willy
![]() 2011MY 110 XS USW Black |
Answers,
The gutter sealant was used as the foam land rover use to seal the top to the tub is crap. I would recommend using some dynamat on the sides as well as the foam supplied with the mud panels. Normally at 70 mph i have the radio on at vol 27 now its at 21 so a good deal quieter, I think most of the noise now is through the rear and side doors i will do these next. Watch this space for the two major leaks i found today. ![]() 110 HCPU Tipper |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2965 ![]() ![]() |
who is a good supplier for dynamat
opps double post
I got mine off Ebay - The 9 sheet Extreme Bulk Kit should be available for around £130 - I was lucky enough to buy off a guy who had two kits and decided not to use them for a £100 each
If you do the floor and wheel arches you will have one sheet leftover from the bulk extreme pack. So someone needs to source a cheaper alternative that is the same spec. Original Member Pie n Pea Club.
110 HCPU Tipper |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Is ali backed bitumen roof flashing (not lead) not a good 90% alternative?
