|  | Home > Maintenance & Modifications > Removal of plastic side panels in TD4 |
| Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478      | easy matey    pop the black caps off on the seat belts behind there you will see a 17mm bolt which needs undoing, you will need to remove the rear trims on the quater windows aswell they pop off use a bit of force on them. the rest is unclipping trim clips and on later 110's there are a few screws once everything is out lift up the top of the side trim and pull out (there are l shape brackets which are on the trim which go and sit into the inner roof gutter keeping it up there) if you look in the alpine windows in the roof youll see the clips im talking about    CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive | ||
|  19th Nov 2012 8:57pm |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387    | Just look carefully as you take the seatbelt bolt out, make sure each washer/spacer etc is noted in which order they come off   QRZ M8VPF | ||
|  19th Nov 2012 9:02pm |
| Destromat Member Since: 19 Nov 2012 Location: Birmingham Posts: 2  | Thanks so much for this great and clear advise! I really appreciate it! Can upload pics of the net system when installed if anyones interested.
 Actually very difficult to find anyone else that's done it. Cheers guys, great forum  | ||
|  19th Nov 2012 10:13pm |
  get the pics up mate, im considering fitting the mud uk panels to mine there like the land rover trim but are filled in with a built in net which will be handy  CSK Automotive www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive | ||
|  19th Nov 2012 10:30pm |
| All times are GMT + 1 Hour | < Previous Topic | Next Topic > |
| Posting Rules
