![]() | Home > Maintenance & Modifications > Defender 130 - rear seat box question |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
Any reason why I can't form a lid in the rear seat box of my Puma 130 ?
My Td5 130 has a lid and is great for storage but the Puma is a one piece box with no opening, is there a reason why ? |
| SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527
Don't know but why not cut a hole in your one first then if it's OK I can do mine. :rolllaugh:
Excellent reply
I'm guessing it was easier for Land Rover to not cut a hole as there are the additional brackets for the new rear seats, can't see why it wouldn't be ok, may need a little bracing that's all |
In which case, it is my duty as a supplier of (British made) parts to investigate this for you and report back
I've fitted it in nearside floor plate now.
Ahh, OK.
Well, I'm going to investigate anyway as I want to fit a Viair twin compressor and air tank in there |
Fitted ARB twin under 40 seat fits a treat.
Yes, I saw picture, looks good !
I've had a look and there just isn't room for my set up unfortunately |
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711
Why not sink a box into the floor between the chassis.
Click image to enlarge 130's have feeling's as well you know |
Hi Andrew, I presume that is set into the floor under where the seat box is sited ?
So, no reason not to do the same thing in the top of the seat box ? |
Yes and Yes you could
Excellent
Thank you |
