Home > Technical > Engel MT45 not working
nivmargalit
Israel 2007 Defender 110 Puma 2.4 SW Stornoway Grey
Hi
Engel MT45, In the last time make some problems:
In the begining it not cooling very good, the compresor work and it not keep a stable temp.
After that in the display screen it show "B" and the green light was off and the temp was arround 16 - 17C
after that it work again, now when I open the switch I only see the temp, and it not work.
What you think the problem should be ?
Thanks
Niv
Post #185572 16th Nov 2012 2:09pm
speedymarktd6
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Epsom Green
Are you able to get it re gassed perhaps i dont no anything about engel fridges but ive worked on a few comp driers so similer principles
Post #185581 16th Nov 2012 2:58pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
have written about mine and repair/measurement values on here somewhere, sure the search function will bring it up.
Anyway the Engel is basically 3 things:
- Random stuff: Temp sensor, ventilator if turbo model, switch panel: these seem to work from your explanation
- Compressor: works or is broken, you can measure the resistance(look for my posts, i have the correct values in them)
- Control unit: 1 piece replacement, around 280£ and most common failure.
Gas is the normal reflex of everyone but never heard of one actually leaking.(but most all of them being suspected at first to have a gas leak)
FYI Engel has good worldwide aftersales, even if 20 years out of warrantee and with international equal parts pricing.
Ask australia direct and they'll point you in the right direction (a lot of their service partners are not even advertising as such, so hard to find them yourself)
2cents only
Smile
Post #185599 16th Nov 2012 3:45pm
nivmargalit
thanks for your comments.
one more info, when it plag to 220v it works grate.
can it be the car battary ?
Post #185737 17th Nov 2012 12:26am
landy andy
I would change the 12 volt power lead as these can fail. Mine did even though I thought was ok and problem was fridge, but was sent new lead and all then ok.
Andy
Post #185745 17th Nov 2012 4:41am
SGH
I could be worth checking to 12v lead first but if it runs and cools on 230v and not on 12v then it's a power supply fault.
Post #185898 17th Nov 2012 7:39pm
nivmargalit
I plag it in my friend car and it works ok . Very Happy
So, the problem is in my car - or the battery or the line from the battery to the fridge.
Thanks I will update.
Post #186092 18th Nov 2012 5:32pm
tatra805
Yep, that will be wiring or battery
fyi, the 12VDC electronic parts are also necessary when running on 220, iow if the fridge works on 220 the electronics are functional and should also work on 12VDC
I don't have a display model so don't know what messages mean but now reading your post again it looks as "B" on the display means Battery, doesn't it Embarassed
But as said it can be wiring also, Engel has some clever system measuring your wiring. Can be your earth connection is getting worse and this triggering the fault code. (as all was working before)
Post #186280 19th Nov 2012 11:39am
nivmargalit
Update,
The problem was the fuze wire that goes out from the battery, it was too thin.
Now it works grate..
Very Happy
Post #190052 1st Dec 2012 4:35pm
