![]() | Home > Td5 > Rear Shocks - Need Replacing - But with what? |
I've fitted Koni Heavy Trax on the front and back of mine.
Can't fault them ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
May as well go for gas shocks if replacing ........... Terrafirma's are good and affordable.
Why get garage to fit them?? Dead easy do replace yourself [and no labour charge] ![]() |
ben_j85jty Member Since: 03 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 ![]() ![]() ![]() |
OEM is a good bet, ones for my 110 were 27.50 a side.
They replaced a set of TerraFirma that had lasted 1 year, or 4000miles before they snapped at the bottom and top (One each). They cost £50 a side! 2002 Defender 110 DC |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682 ![]() ![]() ![]() |
Mikeyp ...
If you want to upgrade, I suggest Koni Heavy Trax...you get a good price from DEFENDERBITS (Site Sponsor). I just installed mine, and they are a big improvement. If you want standard, I have my take-offs. Only 9000 miles, and as new in every way. £30. (pair) Either way, the rear shocks are a piece of cake to fit (front's are harder)...just a couple of bolts and youre done ![]() Defenderbits link to shocks.. http://shop.defenderbits.co.uk/defender-td...-192-p.asp Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Pam W Member Since: 25 Oct 2011 Location: North Yorkshire Posts: 1169 ![]() ![]() ![]() |
Another vote for Koni Heavy Tracks
(Note. There are 2 types - Heavy Tracks and Heavy Tracks Raid The Raids are about twice the price and unless you are intending to do a lot of high speed off road then the normal ones are fine! Our blog - http://landytravels.com/ Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 ![]() ![]() ![]() |
And another vote for them ![]() |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
Heavy track are the best imho, transformed the ride in mine from a jiggerly truck into a daily drive
![]() Suggest you change front and rear to get the best results BM52 |
mikeyp Member Since: 14 Sep 2010 Location: Londinium Posts: 104 ![]() |
Thx for your tips guys. Under time pressure I just went with OEM; reasonable price. Like a prize c*ck I let the MOT lapse, and I needed the car on the road, having not needed it for a while.
ATB Mike. |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 626 ![]() ![]() ![]() |
Old Man Emu for me, transformed the drive on mine.
![]() Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2684 ![]() ![]() ![]() |
Bilsteins? --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
Are Koni Heavy Tracks rearly worth 4X the cost of OEM?
Merlin |
Merl in, are you sure you are looking at prices for the normal Heavy Tracks ? They are about £70 a corner, not too bad. They are specifically designed for heavier loads in rough tracks but are also great on road. No idea what oem would be but there isn't really one that does the same thing ( for what I need anyway)
However, if you are looking at the Heavy Track RAIDs then they are about twice that so very expensive and are designed for high speed off road (ie Rally Raid ) and therefore the price reflects this. Our blog - http://landytravels.com/ Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net |
Agree - just checked...OE are part # RSC100040 (Front) and £65.99 each. My Koni's were £149 per PAIR... from defenderbits Originals: http://www.rimmerbros.co.uk/Item--i-RSC100040 Koni's: http://shop.defenderbits.co.uk/defender-ko...-191-p.asp Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
