- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
davew
| Late TD5 90/110 measurement... | |
I've got a bit of an issue with Pam's 90 that's been bugging me for a while and I'd like to get to the bottom of it this weekend if I can.
If someone with a late model TD5 90 or 110 (preferable county spec but they SHOULD be the same) could take two measurements for me...
I need to know the distance between the bulkhead and the forward face of the seat box at floor level and also at the top of the seatbox. Essentially I'm after the measurements of the gap the gearbox tunnel covers, if that makes sense. I'd also be interested in the length of the plastic gearbox tunnel at the same points. http://www.yorkshireoffroadclub.net/
19th Oct 2012 5:45pm |
