![]() | Home > Maintenance & Modifications > can you put utility sides onto a standard 110 ? |
| NCTT Member Since: 07 Apr 2008 Location: ESSEX Posts: 229
ok so here is the deal i want a utility BUT not many about privatley and i begrudge paying 20pc vat for essentially exactly the same car
can u mod a 110 to make it a utility ? |
| farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299
yes you can but it won't change the tax status.
also i beleive you can only use 110 sides as the 90 hardtop side length is different. try equicar for parts |
hmmmmmm , thanks farmer
appreciated |
blimey sounds like aklot of hassle
ill pass and keep my eyes open ! |
| Timo K Member Since: 23 Aug 2012 Location: Helsinki Posts: 171
I had my 110 STW converted to a USW by Foley's. You can get the sidepanels from them. About £200 or thereabouts? No big deal. Cheap and easy.
| foxkilla Member Since: 01 May 2009 Location: J23 M1 Posts: 156
You could convert a 110 DC to a USW and maintain the tax status but it is a lot of work, since you'd need to change the rear buck, rear cab panel and roof. The roof should fetch plenty on on ebay though.[/quote]
2 Days work at most once you have gathered all the parts together! hardest part for me was converting full length van sides |
| udderlyoffroad Member Since: 18 Jul 2011 Location: Bristol Posts: 124
Correct - currently have some 88" sides bolted on to my 110 CSW tub. You can pick up an 88" set of vansides for not much on ebay as series folk convert their vans to station wagons. I paid £45 and that included a roof and windscreen! Note however that 88-ers have rear quarterlights wheras USW sides do not. If security for gear was your concern it wouldn't take much to get these tinted - even a DIY ebay kit would cost less than £20 for both. As has been mentioned, none of this helps your tax problem - surely a chat with your account would help you justify a USW.... |
