Home > Puma (Tdci) > 'A' Frame Chassis Brackets
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
Has anyone got a copy of the technical bulletin to fix the 'A' Frame Chassis Brackets or the ball joint. I believe this is the problem behind the "Clank" noise from the rear when changing gears.
Post #174558 10th Oct 2012 9:46am
spudfan
Ireland
http://www.aulro.com/afvb/90-110-130-defen...wards.html 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #174632 10th Oct 2012 6:08pm
Marius
Spuddie, I found that one as well - but the picture is very small and almost illegible.
Post #174773 11th Oct 2012 8:33am
spudfan
Ireland
Hopefully one of the technical guys will post a larger image. They are usually very good at helping out. 1982 88" 2.25 diesel
Post #174897 11th Oct 2012 7:55pm
Marius
FINALLY!!!! New A-frame ball joint and new clutch kit and no more noise!!!!! All replaced under warranty.
Horayyyyyyyy!!!!
Post #180645 31st Oct 2012 2:43pm
bvandyk
Horayyyyyyyy!!!!
Great!!
Post #181283 2nd Nov 2012 1:34pm
