Home > Technical > Diff lock
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
Diff lock
I had cause to put diff lock in today as a precaution going over a saturated field
But no dash light came on so does that its not working or could it be a dodgy dash bulb Thumbs Up
Post #174419 9th Oct 2012 7:00pm
The bulb should be tested every time you turn the ignition on. Does it light up then? Darren
Post #174436 9th Oct 2012 7:24pm
Could be a faulty or badly adjusted switch.
Easy enough to test the CDL, jack up one front wheel and with gearbox in neutral engage CDL. If the wheel turns the CDL isn't engaged.
Post #174525 9th Oct 2012 11:13pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Mines never lit up, apart from when the diff is locked, never lit up when the ignition is turned on though.
Post #175231 12th Oct 2012 9:48pm
Higgers
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Firenze Red
Mine sometimes doesn't light up, but a good wiggle of the lever usually sorts it Thumbs Up
Post #175288 13th Oct 2012 7:51am
jst
the light shouldnt come on as part of the ign on cycle/checks Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #175462 13th Oct 2012 8:16pm
