![]() | Home > Technical > Side Light / brake light measurement |
TD5 (2002) rear brake light is 90mm from the front of the lens to the rear of the connector.
No leads attached as this is the complete unit and on the 2002 MY the loom plugs into the unit. Is this what you need - I have two old brake lights in the storage room ![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6041 ![]() ![]() ![]() |
That great thanks. Do pre 2002 lights alter much in length I wonder.?
Yup I am after enough to do a rear light setup. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Not sure, but if you are after a full set give Andy a ring at Defenderbits, he has both types in stock and I am sure he will supply the dimensions.
Only reason I changed the brake lights on mine was because the lenses had gone dull over the years and on the 2002 type you can't change the lens on its own. You are welcome to the two brake lights I have here. Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
Ahh right.I didn't realise you could swap the lenses. I spoke to Andy the other day.. Doh. 1999 Defender TD5 110
