![]() | Home > Off Topic > Non Permanent Garage |
Landie Boy Member Since: 15 Jan 2011 Location: Essex Posts: 431 ![]() ![]() ![]() |
Hi,
It's got to the stage where because of a well paying apprenticeship that I started I can get a project 90 but due to my dad using up the garage for his stuff I wont have space to keep it while working on it ![]() So after looking on the Internet I came across this, it should have ample space and the height should be just ok (could easily sort it). Space is not a problem thankfully ![]() http://www.dancovershop.com/uk/product/sto...01160.aspx Has anyone had any experience with these? Jack |
Fekete's got one he grows his veggies in! Well something similar.....
![]() http://www.defender2.net/forum/topic6806.html?highlight=tunnel If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
I could see windows being created the first time a grinder is used
Pam W Member Since: 25 Oct 2011 Location: North Yorkshire Posts: 1169 ![]() ![]() ![]() |
We have re-built 4 Land Rovers under something similar on our driveway. Had 8 inches of snow on the top one time. For some reason we end up doing rebuilds in the winter! Our blog - http://landytravels.com/
Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net |
That would be done outside ![]() |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
you could always buy a shed to store the stuff in the garage! BM52
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297 ![]() ![]() ![]() |
A pop-up gazebo from B&Q does me fine for rainy day oil changes etc
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 ![]() ![]() ![]() |
Yes just get yourself a poly tunnel....will also keep you warm ![]() ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
