Home > Maintenance & Modifications > Best Tyre Size for Overland Defender
Page 2 of 3 <123>
Glynparry25
British army have/ still use the XZLs..... along with 265/75/16 Cooper STTs and BFG 28/75/16.
The XZLs go on completely bog standard Defenders (not partuiculary strong- I know from personal experience).
The 265 STTs go on the more modified- SNATCH and WMIK.
The 285 BFGs go on gun tractors and vehicles that need the most traction.
As I mentioned above lots of people go straight for 750/16 tires, this is purely because 10 years ago you wouldn't be able to get anything else than that size in Africa. As always with Land Rover 'It works for the guys in the series 1, 60 years ago on the first overland so it will work for me'........... But it is way better to move with the times and get the best the world has to offer Thumbs Up
Glyn Dog Sheep
Post #173096 4th Oct 2012 4:46am
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
Glyn Dog Sheep
Completely agree with Glyn,
I have 7.5 x 16 XZL on my Defender, chose to fit these after some research for this very question.
I would choose a tyre most suitable for the places you wish to travel, maybe the XZL was the best allrounder in the past but definitely not now.
I would choose an All Terrain Tyre now. We recently had a Landrover in Africa and it had on it what looked like Michelin 7.5 x 16 road tyres, I was really scepticle but wow they were brilliant nice on the road and got us through some really deep sand. The 7.5 x 16 is a good size no problem there but the tread I would choose carefully.
Another point on my XZL's, in the snow on tarmac last year they were lethal.
My travelling in my Defender unless I win the lotter will allways be in Europe so my next tyre choice would be and all terrain 265/75
Steve
Post #173110 4th Oct 2012 7:59am
drive4change
United Kingdom 1993 Defender 130 200 Tdi HCPU Alpine White
I was originally thinking of a BFG it seemed to me that many overlanders were using them. I will be carrying a minimum of two spares but would rather they stayed spare lol Has anyone had any strength issues with the BFG AT?
Post #173124 4th Oct 2012 9:10am
spudfan
Ireland
Glynparry25 wrote"But it is way better to move with the times and get the best the world has to offer "
Like the Puma. Thumbs Up 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #173148 4th Oct 2012 1:27pm
leeds
drive4change wrote:
..... I will be carrying a minimum of two spares but would rather they stayed spare lol .....
Where are you planning on going that you will need more then two spares?
My experience whilst travelling is that you get more punctures in towns, normally from things like roofing screws!
Once got a roofing screw through corner of side wall which legally is irrepairable. So had to get a replacement tyre in from 2,400 miles away! Took a week to arrive so I just pottered around the local area for a week.
The philsophy when you get a puncture is to repair the puncture and preserve your spare tyres. Otherwiise you run the risk of having to repair two or three tyres!
Get yourself a good deflator, compressor and repair kit.
Also remember you need two mean of undoing wheel nuts, two means of jacking the vehicle and do not forget the folding axle stand.
Brendan
Post #173211 4th Oct 2012 8:13pm
drive4change
In your opinion is a Warn Powerplant a good compromise as a Winch / compressor / deflator in one?
Post #173239 4th Oct 2012 9:27pm
leeds
Normally I dislike things which are made to do several functions, however that is one of my endearing foibles Razz
Have not used the Warn Powerplant but we have Warn winches on our vehicles.
The Warn Powerplant specification are
Quote:
POWERPLANT HD SPECS/PART NUMBER
Part Number: 71801 (12V)
Rated Line Pull: 12,000 lbs. (5440 kgs) single-line
Motor: Gen ll Series Wound 4.6 hp 12V, with Thermal Protection Shutoff Switch
Electrical controls: Contactor
Remote Control: Remote switch with Thermometric LED and 12 in (3.7m) lead
Geartrain: 3-stage planetary
Gear ratio: 216:1
Clutch (freespooling): Sliding ring gear
Brake: Integrated direct-drive cone brake
Wire rope: 80 ft of 3/8 in (24m of 9.5mm diam.)
Fairlead: Roller
Recommended battery: 650 CCA minimum
Battery leads: 2 gauge, 72 in (1.83m)
Finish: High-gloss black powdercoat
Drum diameter/Length: 2.5 in /9 in (6.4cm/23cm)
Weight: 115 lbs (52 kgs)
Air Reservoir: 1/2 gallon with Integrated Air Intercooler
High Air Flow Rating: 12 CFM @ 0 psi, 5 CFM @ 90 psi
Max Air Pressure: 100 psi
Air Pressure Switch: Yes
Air Hose: 12 ft nylon, with quick-disconnect. Brass air fittings and couplings
Now that high pressure flowrate is good Thumbs Up
Downside is length of hose at 12' but that is easily extended which you would need for a 130
Retail price is £1908
The smaller one
Quote:
Part Number: 71800 (12V)
Rated Line Pull: 9,500 lbs. (4310 kgs) single-line
Gear ratio: 156:1
Wire rope: 125 ft of 5/16 in (38m of 8mm diam.)
Fairlead: Roller
Drum diameter/Length: 2.5 in/9 in (6.4cm/23cm)
Weight: 100 lbs (45 kgs)
Air Reservoir: 1/2 gallon tank with
High Air Flow Rating:: 12 CFM @ 0 psi, 5 CFM @ 90 psi
Air Hose: 12 in nylon, with quick-disconnect. Brass air fittings and couplings
Looks like the same good compressor Thumbs Up
125' of wire is better Thumbs Up
Retail price is £1817
We can supply either of those Warn winches. When you decide which winch etc you want give us a bell and will see what price we can do them for.
Brendan
Post #173265 4th Oct 2012 10:16pm
wslr
Most areas you are going in Africa, you'll find any small village will have a bloke who can fix tyres, provided they are tubed. Tubeless would be a problem unless you learn to fix them yourself.
Also steel wheels help as you can smack them back into shape whereas alloys will probably crack.
2 spares a good idea. I always carried 2 even out on local journeys. The Firestone factory out near Nairobi's JK airport was still producing the 205/16 Town and Country which was ideal as a tubed 4x4 tyre, and even some of the locals used these to rally with as they were cheap and reliable.
My brother did the Cape Town trip a few years ago using the KL71 tyres, which were good except that they couldn't locate replacements easily and even considered asking me to send a set out to Nakuru.
If you take the tubeless route, I'd personally be using some Tyre Seal. Unless you get creative, most of the trip will be tracks/tarmac and this stuff is pretty good. It will seal a 9mm round shot into it provided you are moving, so acacia tree thorns are no issue.
Also, on this note, some of these areas are risk areas. You may be forced off the road or even have stinger type tyre deflation (locally made so it probably won't work) put out in front of you, so having the ability to get past this fast which the Tyre Seal will allow. Bonus is that you can wash this out of the tyre as it stays a liquid inside the tyre under normal conditions. Good stuff which is cheap and it sells well as a result. However, as you are in a 200tdi 130, fast may not be an option. Laughing
Post #173266 4th Oct 2012 10:17pm
drive4change
Thanks for that Richard Rolling with laughter
Of course, a voodoo exhaust system would definitely help Whistle Bow down
Steve
Post #173337 5th Oct 2012 11:41am
I personally wouldn't have a Warn dual winch thing up front, too heavy, possibly wipes out the whole lot in a front end bump, too nickable, too expensive
There are plenty of good quality portable compressors on the market to choose from, cheaper, lighter, can be used on other vehicles without having to move your vehicle ....
Post #173339 5th Oct 2012 11:47am
drive4change
That was a school of thought Matt. We have plenty of space in the rear to be able to carry a portable compressor if that is a better way to go. Thumbs Up
Post #173340 5th Oct 2012 11:54am
Only my opinion ....
If not portable, take a look at the range on Matt Savages site of fitted compressor set ups ...
Post #173341 5th Oct 2012 11:56am
drive4change
All opinions much appreciated Thumbs Up
Post #173342 5th Oct 2012 11:57am
wslr
Steve
Yea, noise is something which you tend to get a response out of people, certainly in East Africa. Thumbs Up
I think the Voodoo system is a certainty, but perhaps run it down here when you have done the work on the truck and it can be built then. No point copying the original as you can't make any improvements except with the materials used.
Post #173346 5th Oct 2012 12:18pm
drive4change
Sounds great Thumbs Up
The new galvanised chassis being donated to us by Marsland Chassis UK will be arriving in 2 to 3 weeks. At which point we hope to be able to get some real time dedicated to rebuilding. Very Happy
Post #173349 5th Oct 2012 12:24pm
Page 2 of 3 <123>
