Home > Maintenance & Modifications > Defender happy kit |
What you going to use the three pin plug, chopping board and Union Jack tray on? The tray I can understand if snow's forecast!
How many miles you got on your truck if you don't mind me asking and is it a Puma? Just curious? I drop the engine oil every 6K! Personal choice. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
1st Oct 2012 12:36pm |
mermoto Member Since: 21 Sep 2011 Location: Essex Posts: 326 |
3 pin plug for heating water for my cuppa tea on my patriotic tea tray Its an 08 Puma and only done 18,000 miles but I am doing all the oils. Also testing my new Super Tool, pictures to come |
1st Oct 2012 12:47pm |
Mermoto,
You would have seen it on the other thread but get one of these: www.drainplug.co.uk/accessories.html It makes future oil changes so much quicker and so much easier with no mess. I don't do dirt very well and neither does the Missus especially when you get oil on the block paving! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
1st Oct 2012 12:54pm |
ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731 |
In the 80s I had a quick-change oil plug on a souped up Talbot Horizon. Stuck out below the sump about an inch and a half.
A couple of days later, I was showing off to my brother in law and flew over a humpback bridge. Luckily there was no-one behind me when I landed or the black smoke would have killed them I had to hammer a bit of tree branch into the hole so I could drive very slowly home Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
1st Oct 2012 1:35pm |
Yes I have thought about these kits in the past. Any idea of cost? Mermoto |
1st Oct 2012 1:50pm |
About £35..... If you go through life with your head in the sand....all people will see is an ar5e!!
1st Oct 2012 4:05pm |
and get the drain tube fitting too and keep it in the truck
1st Oct 2012 5:54pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2086 |
The drain plugs are worth every penny
Mo The Land Rover 90 - Many are called, few are chosen. |
3rd Oct 2012 8:27pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
good to see quality products being used, instead of s.hitpart CSK Automotive
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
3rd Oct 2012 8:32pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
why so much oil ?
iv only put 2 ltrs of oil in my new gearbox as if you put what LR say it spurts it out the breather that cost £40 for those 2ltrs steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
3rd Oct 2012 8:35pm |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
Its a great feeling to know that all the lubes are the correct type used in the correct quantity. I changed all mine as soon as I got back from the dealer !
Don't forget to grease the props ! |
3rd Oct 2012 8:47pm |
TD5_90 Member Since: 02 Apr 2011 Location: Perthshire Posts: 89 |
Every 6k and good quality oils gives peace of mind.
Not wanting to go or hijack the thread - I have just done a fluids change on my Td5, with temps dropping up here already I have noticed the sticky 2nd gear and going to put difflock evo oil in the gearbox again. Anyone else know of a cheaper but equivalent solution? |
3rd Oct 2012 10:15pm |
yessss I have it and it is fantastic!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
4th Oct 2012 12:08am |
