![]() | Home > Puma (Tdci) > Replacement Vehicle Alarm |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
http://www.mobilecentre.co.uk/index.php?ma...cts_id=637 Controls off the standard Land Rover Alarm.... You can't just remove the LR system completely as interior light won't work, and you need to remove the standard immobiliser function. I'd personally integrate with what is already there. Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
brightondefender Member Since: 14 Jan 2012 Location: East Sussex Posts: 98 ![]() ![]() |
Thanks for that Ian I will look into it |
There are of course easier and cheaper options in the interim like a decent pedal lock, filling the door hinge bolt heads with resin the cycle lock/chain for the bonnet through the engine lifting eye etc.....Anything really to slow the toe-rags down. If you go through life with your head in the sand....all people will see is an ar5e!!
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
You forget valve cap theft too Mal
![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Surrey Rover Member Since: 20 Dec 2010 Location: Surrey Posts: 360 ![]() |
Being the paranoid type, I had a Clifford G5 fitted to mine.
I had no issues with the interior lights or the central locking etc, it just worked as normal. I liked the chirp/barrier feature, when you got close it sounded just to let you know it knew you were there. My wife hated that feature which made me like it even more ![]() 2.2 110 Tipper |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 ![]() ![]() ![]() |
brightondefender, i could be keen to get an upgrade too on mine. please let me know what you find and if 2 would make any difference on price/fitting.
Did you have two alarm fobs? standard LR and Clifford? Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 ![]() ![]() |
Yep more details please surrey rover It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
Me too..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
No, single key fob. I obviously kept the originals and gave them to the new owner when I sold it with the truck but they were in effect redundant. Not much more to tell you really. Nick
2.2 110 Tipper |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
Nick is the clifford alarm shock sensitive, so if the
![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Yes, it has a tilt and motion sensor, glass tamper, warn away and ultrasonic interior sensor (hardly worth it with the tiny 90 pickup cab) Pretty much everything you need to stop all but the most skilled/determined. It also had a funky blue flashing light, worth it just for that ![]() 2.2 110 Tipper |
![]() ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Was that when you were looking for Keswick green under car neon kits on there too ![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
