Home > Technical > Washer motor upgrade?
I've fitted the twin washer nozzles to my 110 (Td5), it's great for getting more water onto the screen.
However, at anything over walking pace, there isn't enough pressure from the pump to really blast the screen, compared to modern vehicles with a similar nozzle setup.
Does anyone know of a replacement pump that will clip straight into the Td5 washer bottle, that will give better results?
Or can an external pump be fitted with the "suck" pipe fitting into the hole where the original pump would have sat?
Post #171788 29th Sep 2012 4:54pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Re: Washer motor upgrade?
Do you have a rear wash wipe? If your 110 is a DC then you could have one motor for each side of the screen!
Post #171794 29th Sep 2012 5:21pm
Nah, station wagon so the rear pump is in use.
Post #171906 29th Sep 2012 10:13pm
defender4
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
I've been thinking along the same lines i.e. additional washer nozzle and more powerful washer pump. I also considered using different washer nozzles with a spray/ mist / fan shaped pattern for greater washing efficiency but drew a blank on that. I am told that a better pump can be probably be fitted but haven't got any further on that yet. I believe that a headlamp washer pump might be more powerful - the risk is, of course, that if it's too powerful it blows the system apart at some joint along the route from reservoir to nozzle.
Do you have any pictures of your twin nozzle set up?
Post #171945 30th Sep 2012 8:15am
grafty99
could you mount some VW / Audi ones in the bonnet like a normal car? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #171965 30th Sep 2012 9:33am
defender4
Possibly but it would mean cutting holes in the bonnet so you would want to be damn sure that it was going to work first.
Post #172373 1st Oct 2012 11:54am
But at least you'd be able to recognise your bonnet when it turns up on ebay!
Post #172390 1st Oct 2012 12:34pm
defender4
Laughing
Post #172394 1st Oct 2012 12:37pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
an't get it off can they Defender4.....we've covered the hinges in Wurthers wrappers.. Wink Whistle Putting Dreams on Drives at JLR Solihull..
Post #172435 1st Oct 2012 2:39pm
defender4
Spot on! Thumbs Up
Post #172437 1st Oct 2012 2:42pm
