Home > Technical > P38 diff into front axle???
I've had some ideas for my next project, and wondered what the concensus was....
As usual with my projects, I start with the axles. nice and fun Cool Cool I'll use a normal late 110 rear axle with the P38 diff, going to add the braces a la Wolf XD axles. same on the front.
however, on the front, I was thinking of fitting a P38 diff.... I figure they're stronger than a normal Rover diff (otherwise why would LR use them in P38's and 110's??)
Looking at a Rover diff vs. a P38, the depth looks the same, and I've got the chance of an old P38 axle case, so I could cut out the retaining "ring" bit and weld this onto a normal 90/110 front axle to fit the diff in. Halfshafts look to be the saame dimateter and spline count.
What do people think?
cheers :kiss Wink
Post #170119 23rd Sep 2012 10:17am
noworries4x4
Disco 2 is the same as P38 except the right way round diffs on the drivers side and the exposed cv unit with ball joint hubs, very strong only drawback is the wheel bearings come compleat as a hub assy unless you have a 60t + press with special tooling but even then they can just smash the hubs, just use a Disco axle as is modify the mountings as required easier way of getting the strongest axle out there, apart from a Sailsbury but the unspung weight issues that they bring with them far outweigh their strength, If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #170128 23rd Sep 2012 10:42am
Cheers for that Thumbs Up
Although I'd prefer to keep it a defender axle, as the width will be the same as standard, plus it'll take defender wheels.
Post #170141 23rd Sep 2012 11:35am
Landyphil
United Kingdom 2003 Defender 110 Td5 USW Stornoway Grey
If you want to keep the Defender axle but want more strength with P38 parts what a lot of fellow trialers "just" change the diff carrier over into a conventional rover diff.
Bit of a halfway house but once pegged the end result can be pretty strong.
Other than pegging and rebuilding and never done a P38 4 pin carrier swap but I've been told it does require a bit of trimming.
Has anyone on else here done it? 90XS Tdci John Eales
110 CSW G4 Edition
88" Series 3 Racer
Post #173441 5th Oct 2012 7:59pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
I did the opposite, putting a rover center into a P38 diff. (well a rover sized/designed ATB in this case)
For that you need a spacer ring to correct the ring to pinion distance (goes between center and ring) Ashcrofts sells them together with the longer bolts.
So the opposite way would mean you'll have to machine off about 2-3mm of the ring contact surface on the P38 center to get the ring in the right position in the rover diff. (dont ask me to take out the diff and measure the spacer Cool )
I was told only the V8 P38 has a 4 pin rear diff, all others are also 2 pin. (and all fronts are 2pin) Never checked this though and no idea about D2 diffs.
Smile
Post #173447 5th Oct 2012 8:12pm
Yeah, the 4.6 P38 rear is a 4 pinion, and fairly cheap.
I might just go the route of fitting the diff assy into a rover (90 front) casing and be done with it.
Post #173454 5th Oct 2012 8:54pm
T1G UP
i got 2 x p38 diffs for my 100" project. they require a bit of machining but will fit .
i've got some pics etc of how they should be machined to accept the defender r&p
Post #173469 5th Oct 2012 10:07pm
I believe that the reason the P38 diff was used originally was because there wasn't a 4 pinion Rover diff until the unit for the Puma front axle was developed c.2008.
As far as I know the 4 pinion Rover diff is just as strong as the P38 and a lot more so if you fit an Ashcroft HD ring and pinion. ATB diff, and possibly get it pegged. Only downside, it's a lot more expensive.
Post #173490 5th Oct 2012 11:06pm
Pics would be good Marcus.
Blackwolf.... the old V8 90 had a 4 pin rear (rover type) diff back in the 80's.
Post #173514 6th Oct 2012 8:09am
T1G UP
Post #173517 6th Oct 2012 8:12am
