![]() | Home > Technical > 2012 110 uxs 2.2 tdci - Indicators not working - now working |
| NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 291
Strange occurance, I was indicating to turn right, only the indicators did not flash, but staid on?
Found a place to pull over and park to investigate, indicated to turn left, same thing, without stopping the engine, checked the indicators right and left, no flashing but indicators on. cheked the Hazard Flash, exactly the same, no flashing? Turned off the engine, on re-starting everything worked perfectly, and has continued to do so. Anybody any bright ideas as to the cause? NormanD WE191 2015 110 XS Utility 2014 VW Caravelle 180 Executive |
| Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507
Probably just the flasher relay stuck ... Guns and Landrovers .... anything else is irrelevant.
| T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101
loose relay, give it a wiggle
| natyeo Member Since: 27 Jan 2013 Location: Bentham Posts: 138
Went to dealers replaced relay , now fine watch this spec 2014 2.2 90 hard top , Warm M8000 , Scorpain winch bumper, Ashcroft rear atb
2012 2.2 tdci 110 Utility 1993 110 CSW Warn M8000 , Scorpain winch bumper , 2" lift , Roamerdive overdrive, on going 1971 Hybird 200tdi, 2 x truetracs,Extrem winch bumper, M8000, GKN overdrive & Coils 2" lift, Glynn Lewis cranked rear trail arms 1971 Series 3 88, Perkins 4203,M8000,SATs,O/D, |
